hallmark007
Flight distance : 9827923 ft
JayMar59 Posted at 2017-1-17 14:03
One more thing, it looks like it got delivered today and the status is "on file" will I be notified when it is checked into the repair station? Thanks Ken.
You will be notified when it's assessed by email usually takes a couple of days, once you agree to pay or use dji care refresh, it will move very quickly after that,
You can also follow progress on the app here.
On opening page click on More, then dji support, then repair history.
Sorry to hear about your crash.
Flying indoors is always going to be a tough test for new pilots.
When flying indoors first set RTH to hover then make sure there is plenty of light and some kind of pattern floor, fly in opti mode with VPS on if mode changes to gps you will be fine more control , problem is if there is a problem with VPS the mode may change to Atti and aircraft will drift, and to fly properly in Atti it helps to have some experience.
I would suggest when you get it back you go to the open field and get some flying with the Mavic under your belt. Good Luck.. |
