HDMI Output Module
8028 17 2017-1-15
vik1967
Flight distance : 559551 ft
Belarus
Is HDMI module is suitable for  Phantom 4 PRO console? http://store.dji.com/product/pha ... ;from=insite_search
2017-1-15
ePetLicensing.c
Yes you can use but very careful when pulling out the thin electronic wires or you will have a bust.
Also remember to shut down and restart after install.
2017-1-15
DJI Natalia
Flight distance : 318 ft
Yes, it's suitable for P4P, please upgrade the firmware after installing the HDMI.
2017-1-16
TheMann58
Flight distance : 18669501 ft
Yes, I can confirm that the HDMI Module works on the Phantom 4 Pro (P4P) RC. I installed a spare Phantom 3 Spare Part No. 54 HDMI Output Module that I purchased about 1 year ago on my new P4P RC two days ago and tonight I tested it and confirmed that I can get simultaneous output of live P4P camera video to both my iPad Air 2 connected to the USB port on the RC and to my Yuneec Skyview FPV goggles connected to the HDMI port on the RC.
Remember - in the DJI GO 4 app, under the HD menu, you will need turn on the slider switch for "Simultaneous image output to app and HDMI." Before turning this slider on I was seeing no live video on my connected iPad.  So, at least for the iOS version of the DJI GO 4 app, this slider switch is used to enable or disable live video display to your connected iPad / iPhone screen. The output to the connected HDMI device is ON all the time no matter the setting of this slider switch. This is the opposite of the way you might think this slider switch switch is supposed to work.
Note: Although I had just installed the latest firmware on the RC and P4P aircraft the day before, after installing the HDMI Output Board, the first time I powered up the RC, the DJI GO 4 app informed me that I needed to update the RC again. Possibly - this is necessary to install drivers for the HDMI module.
2017-1-16
fans3208d094
Flight distance : 684170 ft
Can you post a picture of the remote controller after the HDMI module install? Does it fit in the case that came with the p4p?
2017-1-16
TheMann58
fans3208d094 Posted at 2017-1-16 19:43
The HDMI module replaces the I/O module on the bottom of the RC and is several mm thicker than the original equipment I/O module.  Fits in the case with no problems.
Bottom of RC
Bottom of RC
New HDMI Module
New HDMI Module
New HDMI Module installed vs. original P4P Module
2017-1-16
Cetacean
Flight distance : 2528264 ft
Aloha vik,
     As Pet says there are little black lock levers that you have to lift open to remove and reinsert the ribbons.  Be careful, they are delicate.
Aloha and Drone On!
2017-1-17
Paulo Paulino
Flight distance : 2774265 ft
Portugal
This HDMI module on P4P will output 1080p or just 720p?
Thanks.
2017-1-17
fans3208d094
TheMann58 Posted at 2017-1-16 20:28
Awesome. Thanks for the response.
2017-1-17
Cetacean
Paulo Paulino Posted at 2017-1-17 19:10
Thanks.
Aloha Paulo,
     Sorry, the current state is only 720p for HDMI modules.  But, the 5.5" screen of the P4 Pro + (plus) does display 1080p.  Until the CrystalSky monitors come out with their 1080p HDMI ports, you can try the nVidia Shield K1.  The HDMI output on the Android device is at 1080p with the P4 Pro.  Very nice on a 15.6 inch monitor.
Aloha and Drone On!
2017-1-17
Batatoon
Flight distance : 31079 ft
Portugal
Hi All,
is there a way turn off the display OSD on the HDMI out of P4P+ ?
Thanks!
2017-1-19
RG Drones
Brazil
2017-1-20
RG Drones
Brazil
This link can help you with the installation, I used it as a reference.
2017-1-20
MvZiTaGqtUk8
Flight distance : 333412 ft
TheMann58 Posted at 2017-1-16 18:43
I have this module installed on my RC. I find that when I hook up my Goggles to it via micro usb, the video quality is very pixelated. I have not yet tried the HDMI, because I purchased the wrong HDMI cable. Have you been able to get a good video feed? I've read that the HDMI module is capped at 720p.
2017-6-25
aunaste
Flight distance : 2064140 ft
Estonia
MvZiTaGqtUk8 Posted at 2017-6-25 06:04
I got message "Mobile device CPU fully loaded. Related performance will be affected." on my 128GB iPhone 6S after installing HDMI output module. Picture flickering and sometimes just green. HDMI output is fine, old iPad Air (2013) works fine.
When I switched back original module, iPhone 6s works fine.
2017-6-25
BobStekeur
Does anyone know if the HDMI module in the Inspire 1 is the same as the P3 and P4?
2017-6-27
RimMap
Flight distance : 111529 ft
Installed July 19th. Also got the flickering and the occasional green screen on 2.4 set to auto. If custom was selected w/ a set channel,we got smooth feed in iPad mini4 & hdmi output to a tv. Didn't work on 5.8. Also having some problems with GS Pro and Drone Deploy after the install. Not sure if the problems are related to the he HDMI module or not.
2017-7-26
Capo
Flight distance : 178196 ft
Thanks.
720p, however the image quality is much better on HDMI than on USB at this time. 720p on the HDMI module is actually pretty good.
2017-7-26
