Cetacean
Flight distance : 2528264 ft
fans7a3c33ca Posted at 2017-1-17 02:28
My live feed on my p4 is so garbled I can barely use it. However...oddly I can disconnect the cable from controller to the NVidia Shield I bought hoping the NViDIa's mor "gamimg" power and speed would solve it. Did I get a bad cable? Other suggestions. And yes I cut the image quality way down...same thing. Dji..how can I get help on this and a couple more cords before sendimg it BACK in again for repair please. Of note it has the updated HDMI module on controller
Thanks , mark
Aloha mark,
My P4 is working very well with the nVidia Shield K1. Yes, a bad cable can cause problems, try another cable but do not coil it if it is long (that creates interference). If it works, buy a 1 foot data cable, shielded if possible.
The nVidia Shield K1 needs to have all apps not involved with flying disabled or deleted. There is an option to allow only one app to operate and/or one in the background. No more than one in the background. Multiple apps can make even the fastest tablet mess up.
When you say you cut the image quality way down is that in the HD option or in the recorded camera controls? Also, how is the quality in the HDMI view? Note that Spirytus said he reset the camera settings. With his particular problem that alone could solve his problem, so maybe it can help you.
You appear to have what you need to resolve this issue but you have to test the options.
Aloha and Drone On! |
