Ppaggeau
Zemnuse Z3 SOLVED, this is what i had to do at the request of DJI.
Chris (Support)
9月25日 CST17:58
Hello Patrick,
Good day.
Thank you for keeping in touch. For the reset process, you will have to downgrade firmware for this unit. At the main aircraft screen of the DJI GO app, please press and hold the graduation icon located at the upper right corner for a good 5-6 seconds and then release. After you release the icon another screen will pop up where you can see the list of firmware version. Choose the next one from the latest and make sure that this is successfully completed. After this, update the firmware again to its latest to refresh the firmware and also make sure that this is successfully completed.
after you downgrade firmware on the remote make sure you upgrade firmware on the aircraft, just do it anyway it will tell you if its the same version your trying to upgrade too or it will ABORT saying its the same, then start everything up and let the dji go app inform you that an update is required and do it, This worked for me.
Chris
DJI Technical Support
Website: http://www.dji.com/support
Youtube: http://s.dji.com/Youtube-DJI
Thanks
Patrick
