Donnie Stugots
Flight distance : 3636782 ft
flamingjeff Posted at 2017-1-21 02:19
Hello, I'm also having problems updating to (v1.10.01.40).
I have the inspire 1 V2 with X5R camera.
The aircraft has updated fine however the app has a warning message saying the camera requires an update. When I navigate to the "about" section in the app it shows the camera and aircraft are running the new update.
When you did update you used the X5 Raw camera correct and you did choose the X5 raw from the drop down "product select " correct ? OR if you went direct to the RAW page that is fine also , just as longas you did not use the X5 standard FW, you don't have any other camera correct ?
Can you please double check Camera FW version on the About Tab says ? If it says 1.10.01.40 for both the AC and the Camera then you are fine .( and you are positive you used the RAW , and not the PRO firmware )
Here is another idea :
Sometines the servers need to catch up, I would make sure your Go app device has internet connection , then fire the whole system Up and get the motors running . This may prompt the go app to realize that the system is updated and the servers will turn off the message .
Do you get the "success" message on the SD card after updating , if not make sure you do . Just load the SD card back to the PC or Mac and go to the "Result Log" You could also go to the Hidden file to read the whole thing . If you dont know how here is a link .
How to View Hidden Files: Tool to diagnose No signal and SD Issues
Give this a try anyway and let us know if it clears .
Also be sure to tun off go app devicde completely and then reboot a few minutes later and see if that might help as well .
donnie
