Update 1.0.7 A3 N3
1524 8 2017-1-18
fans9efd1eab
Austria
Hallo, i updated my two Fcs and now i cant connect them to the assistent2 any more.(i tryed Assistent v1.0.5 and v1.0.9)
It is in loading and nothing happen in both controllers the same way. Is there a chance to downgrade or set them to factory state? What can i do?
2017-1-18
ducpeter
Flight distance : 62175 ft
delete your old Assistent 2 and install the new one from today
2017-1-18
fans9efd1eab
Austria
From today? I only have the 1.0.9 from 05.01.16 , is there a newer one?
2017-1-18
fans9efd1eab
Austria
It connect sometimes, but i cant do any thing. This is the screen i see. In dji go app everything is great. But everything is on default setting
2017-1-18
SkySight Aerial
Flight distance : 3312018 ft
fans9efd1eab Posted at 2017-1-18 10:52
You need the latest version of Assistant 2 V 1.0.9-2 released today. You can upgrade the firmware from the previous version but all you get is a 'no entry' icon when you try to use it. I had the same issue but the latest Assistant solved it. You will have to start the setup from scratch though.
2017-1-18
fans9efd1eab
Austria
Thank you very much, do you have a link? I cant find it. Sorry
2017-1-18
fans9efd1eab
Austria
Found it... its only on m600 site. Thank you
2017-1-18
DJI-Jamie
Flight distance : 112405 ft
fans9efd1eab Posted at 2017-1-18 11:34
Good to hear you found it, let us know if you run into any other issues.
2017-1-18
fanse2fa4e88
Flight distance : 375761 ft
Update 1.7.0.0 seems to break compatibility between Onboard SDK 3.2 and N3. Initialization reports incompatible drone version.
2017-1-20
