New Inspire 1 1345LS Quick Release Propeller Mounting Plates
123Next >
18644 105 2017-1-18
fans39c5c42a
Flight distance : 123268 ft
The new hubs come with foam plugs. Can you indicate where these are used?
2017-2-23
RichJ53
Flight distance : 1837356 ft
Nigpd Posted at 2017-2-17 13:42
Still no reply from DJI.  Useless c*ckwombles
My prop hub order has shipped (finally)
Rich
2017-2-23
RichJ53
fans39c5c42a Posted at 2017-2-23 06:59
I believe these are used inside the propellers inside the top. Similar to the Inspire 2 version 2 props. The foam will apply some downward pressure once the props are locked into the hubs.
Rich
2017-2-23
fans07479590
Flight distance : 491811 ft
Does anyone know what the little rubber like things are for that cone with the 1345 ls adapters?
2017-2-24
Nigpd
Flight distance : 597677 ft
RichJ53 Posted at 2017-2-23 21:12
Hope mine aren't too far behind
2017-2-24
fans17a5a848
Flight distance : 214367 ft
http://dl.djicdn.com/downloads/i ... +Kit+User+Guide.pdf
2017-2-24
RichJ53
fans07479590 Posted at 2017-2-24 11:41
read my post #47
Rich
2017-2-24
RichJ53
Nigpd Posted at 2017-2-24 13:46
Hi Nigpd
I hope so too.... I have the tracking number now and they will be here next week
Rich
2017-2-24
RichJ53
Donnie Stugots Posted at 2017-1-26 05:26
Sure looked like the blue Loctite to me .  That is what I have used in the past .  Just a drop , a little goes a lonnnnng way . It has a funny  sweet taste also ...........
donnie
Donnie
The official DJI instructions show Loctite 243.  check post #45
My hubs were just shipped
Rich
2017-2-24
Darioluna
RichJ53 Posted at 2017-2-24 21:59
Donnie
Hello Rich,
I purchased the 1345 LS mounting plates and after installing them I noticed that both CW propellers wiggle when they are locked onto the CW mounting plate (i've tried 4 different 1345T  CW propellers on both cw mounting plates and get the same results). I don't encounter this issue with the CCW mounting plates and propellers.  I have contacted DJI about this and I am still waiting to hear back.  When you install your mounting plates please let me know if you also encounter this.   thank you.
ruben
2017-2-25
RichJ53
Darioluna Posted at 2017-2-25 12:32
Hello Rich,
I will get back to you after they are received and installed. Did you put the foam inside the props? I think this will put extra downward force on the hub connection...
Rich
2017-2-25
Darioluna
RichJ53 Posted at 2017-2-25 15:55
Rich
Hello Rich,
Thanks for your reply.  I placed the foam on all 4 of the CW propellers I tried and had the same result on both CW mounting plates.  Again, I thank you very much for your input.  I will be checking in from time to time.
Ruben
2017-2-25
RichJ53
Hello Rich,
Hi Ruben
That is strange because the red CW props are the ones that are slightly loose on my Inspire with the other hubs. The white CCW props are tight and you cannot get them to move after they are locked into the hubs.
I slight amount of play would most likely be normal and once the hubs are locked, I would think everything should be just fine.
Keep us posted and if you want to show us by making a video that would be great.
Rich
2017-2-25
darioluna1
hope i did this correctly.  ruben
2017-2-27
fansf658c209
darioluna1 Posted at 2017-2-27 17:39
I noticed a little wiggle on my red props too. I added another foam insert which seems to stop it.
Also the locking mechanism on the red ones seems more positive than on the white ones. The red ones click into place when there's no prop mounted but the white ones don't have that positive "click" sound or feeling, even though the white props seem more solidly mounted with little or no wiggle in any direction.
I also noticed a little blue loctite on every crew. Is this meant to interact with the fresh glue you are supposed to add to the threaded holes or can they be uses as is with no glue I wonder?
2017-2-28
darioluna1
i just heard back from DJI regarding my issue.  see below.  thanks again everyone for your responses.  ruben
Myra
Myra (DJI)
Mar 1, 00:27 HKT
Dear Ruben,
Thank you for the video that you have provided us.
With your concern, based on the video it would be best if you send the unit to the facility so it can be check by our repair team and also to avoid crash incident which is possible due the issue you have right now.
Please let me know what is your decision and I will assist you here on my end.
Thank you.
If you have any other inquiry in the future please feel free to contact us back anytime and we will be more than happy to assist you with your concern.
Have a wonderful day ahead.
Best Regards,
Myra
DJI NA TECHNICAL SUPPORT
Tel Support: +1(818)235 0789 / Mon-Fri 7:00AM-5:00PM(PST)
Online Support: http://www.dji.com/support#after
2017-2-28
RichJ53
https://www.youtube.com/watch?v=AgHc1Si4w0Y&feature=youtu.be
Hi Dario
After watching your video, that is more play than I would like to see. Thanks for sharing the video.  I just received my new prop hubs today but they did not include the foam plugs for the props.  I most likely will not install these until I get some answers first.
Rich
2017-3-1
RichJ53
Mindy, I received my prop hubs today however they did not send me the foam plugs for the props. Please see post #43, as I did not get these parts with my order.
Can you look into this for me. I do not want to install them until I have everything needed.
order # 0019586705139
Rich
2017-3-1
Movin on
Flight distance : 173455 ft
RichJ53 Posted at 2017-3-1 10:47
You should definitely await those foam plugs.  I received 10 with every 2 lock set, so have extras if you need them.  Just let me know and I can send them to you.
Also, be careful to press in and insert those spring levers on the side when installing.
2017-3-1
RichJ53
Movin on Posted at 2017-3-1 19:35
Hi MO
I purchased 4 sets and received nothing. Thanks for the offer, let me see if DJI sales will respond to my email first.  I agree, I will wait until this gets resolved
Thanks again
Rich
2017-3-1
RichJ53
Hi Mindy
I ordered 4 sets directly from DJI. Can you help me get the foam plugs for the props?  sales response has been delayed and I really cant use the new parts until they answer
Rich
2017-3-2
Henry M.Y.
Flight distance : 11548839 ft
darioluna1 Posted at 2017-2-28 21:52
Myra
Hi Dario (Ruben),
The problem you encountered is relating to minor deviation in manufacturing tolerance of the 1345T props where red props are always a little bit looser than the white props. This problem was well-known to all of us since the 1345T props lock system was introduced in Oct 2015.
It seems to me that the foam insert of the new 1345LS system makes the 1345T props manufacturing tolerance issue becoming apparent - the foam insert jacked the red prop off the prop mounting plate. All the hold-down thrust imposed by the turning buckle (the retaining ring) to the props was taken up by the foam insert at the top centre of the mounting plate (rather than the designed location at the broad base surface of the mounting plate for taking the thrust in order to maintain rigidity of the prop mounting system), loosening the already loose red prop base surface grip to the mounting plate. The result - red prop wobbles and rattles.
I suggest not to use the foam insert for the Inspire 1 1345T props. (The Inspire 2 props mount system is of different design - there are slotted keys in different directions at the prop mounting surfaces for eliminating wobbling and rattling, so the foam insert inside the 1550 props has no adverse effect)
If you still find the red prop rattles without inserted foam, there are different ways to tackle the problem. Here is how I tackle the problem by using black vinyl tape (electric tape) as shim to reestablish the required tight surface grip between the base of prop and the mounting plate in the 1345T prop system. The photos at the end of this post speak for themselves.
The beauty of this method is several folds - (1) vinyl tape is elastic which automatically generates the required shim thickness when it is being compressed under locking thrust imposed by the turning buckle, (2) the vinyl tape maintains large contact area between the prop and the mounting plate, completely eliminate prop rattling when motor spins, (3) the cost is low, re-shimming is easy (no need to loosen any single screw).
The set of the 1345T prop mounting plates and props that came with my Inspire 1 Pro in Oct 2015 are still in perfect condition up to this moment. I logged more than 46 hours of flight time (more than 700km range) without replacing any of the four 1345T mounts, nor replacing any single prop since day one.
Hope this help, and hope you can fly confidently without any need of sending your Inspire 1 with 1345LS mounts back to DJI.
Henry
2017-3-3
Henry M.Y.
RichJ53 Posted at 2017-3-2 11:55
Hi Mindy
Hi Richard,
Those foam inserts are useful for the Inspire 2 1550 prop mounting system only. They are not only useless but also troublesome for the Inspire 1 1345LS mounting system. Please see my earlier post #61 for my views.
If I were you, I would just go ahead installing the 1345LS mounting brackets without inserting any of foam insert into the 1345T props.
Happy flying.
Henry
2017-3-3
Movin on
Henry M.Y. Posted at 2017-3-3 07:51
Hi Richard,
Just curious.  The pictures you have posted are the I-1 V-2 1345T prop locking system, not the new 1345 LS
with the external locking buckle.  Have you tried the 1345LS system without using the foam inserts?
2017-3-4
darioluna1
hello moving on.  i wanted to ask you if your cw props have any play when locked to the 1345 ls prop mounting plate.  i posted a video of my cw props a few days ago which shows a considerable amount of play.  thanks
ruben
2017-3-4
darioluna1
hello henry,
thanks for the information.  i really appreciate it.  the problem i was describing was related to the 1345 ls prop mounting plate.  i am reinstalling my 1345 t  mounting plates.  thanks again
2017-3-4
Movin on
darioluna1 Posted at 2017-3-4 11:21
ruben
None yet.  I skipped using the 1345T locks and went straight from the 1345 quick release to the 1345 LS because of the "non-locking" twist mechanism.  Not much flying time yet with the LS locks, but am checking for play before and after each flight.  So far, so good.
2017-3-4
Henry M.Y.
Movin on Posted at 2017-3-4 09:36
Hi Movin On,
Those are the 1345T system on my Inspire 1 Pro. I have not tried the 1345LS system yet, but the prop holding mechanism of the two systems when locked are very similar - thrust imposed by locked turning buckle on the 1345T is supposed to be taken up by the broad contact surface between the prop base and the mounting plate in order to maintain geometry.
Henry
2017-3-4
Henry M.Y.
darioluna1 Posted at 2017-3-4 11:49
hello henry,
Hi Ruben,
If you can somehow tackle the prop clearance problem, there is no need to go back to the 1345T system. The locking turning buckle with the 1345LS mounting system is wonderful and can give pilots peace of mind, knowing that prop flying off is virtually impossible.
Henry
2017-3-4
darioluna1
Henry M.Y. Posted at 2017-3-4 16:58
Hi Ruben,
Hello Henry,
I placed two foam inserts in the propeller and that seemed to solve the problem but I'm afraid this will put too much pressure on the locks and break them.  I saw a previous post where the locks broke during shipping.  Thanks for helping me out.  It is much appreciated.
2017-3-4
Nigpd
My sets finally finally finally arrived.
Will be fitting them this weekend, with no foam insert in the props, as advised above
2017-3-7
RichJ53
Nigpd Posted at 2017-3-7 12:14
Did you get the foam inserts with your order? Did they come from China or local shop?
Let me know how you like them, if you got the foam inserts, I would use them (IMO) nothing against Henry's statements, just think it really will not hurt anything
Rich
2017-3-8
darioluna1
Hi Ruben,
Hello Henry,
I followed your advise and used electric tape.  CW Props are now rock solid when locked to the  cw 1345 ls mounting plates. My bird is ready to fly.   Thank you very much Henry, I truly appreciate you taking the time to help me out.
ruben
2017-3-9
bobo
Flight distance : 1544416 ft
I believe they go inside the prop center hole to make a tight snug connection when installing the prop onto the hub
2017-3-9
Nigpd
RichJ53 Posted at 2017-3-8 15:42
Hi Rich
Yep, I got the foam inserts.  My order came from DJI China.
I'm divided as to whether to use the foam inserts or not.  I've got some vinyl tape as well, so I'm ready to try both solutions.
Weather is rubbish over the weekend, so I've got time to fit and then try both inserts and vinyl tape to see which is best
2017-3-9
Nigpd
Hi Rich
2017-3-9
RichJ53
Nigpd Posted at 2017-3-9 10:54
Hi Rich
Glad you were finally able to get everything. My order came from DJI CA without the foam inserts...   DJI Mindy never answered me in the forum and I have been having trouble with online sales support. I am waiting for them to answer me on sending the foam propeller inserts!  I know that Henry does not seem to think we need them, but I think they have a reason for us to use the parts.
SO, even though I have the new parts, I am stuck in quick sand
Keep us posted on how it goes, the weather has not been that great here either
Rich
2017-3-9
Henry M.Y.
darioluna1 Posted at 2017-3-4 22:05
Hello Henry,
Ruben,
I'm glad to know you're now enjoying flying the bird without having to set back a couple of weeks returning the Inspire to DJI for diagnosing.
Happy flying.
Henry
2017-3-10
RichJ53
darioluna1 Posted at 2017-3-9 10:29
Hello Henry,
Hi Ruben
I am so happy you were able to get this sorted out. Henry is a great help here on our forum. Did you use both the foam inserts and the tape shim?
Happy flights and take care
Rich
2017-3-10
darioluna1
RichJ53 Posted at 2017-3-10 09:18
Hi Ruben
Hello Rich,
I used one foam insert  in cw prop and tape shim.  I also tried a cw prop with no foam insert and had no play.
2017-3-11
123Next >
