M600/M100 hook to carry and release cargo
2473 9 2017-1-18
LostinJapan
Flight distance : 23054 ft
Japan
Hi everyone,
There are many products on the web to adapt
I cannot find a full solution with a software integration.
The purpose is to release object by pressing C1 or C2
Any advice/experience feedback is welcome
Thx
2017-1-18
Uaviation
Flight distance : 1632106 ft
This might not be the answer that you're looking for, but the simplest way is to install a seperate voltage step, RC receiver and servo (actuator). That way you will have a number of channels to control your gadgets with. If you specifically want to use C1 and C2 then I suggest you ask this question in SDK forums
2017-1-18
lt
Flight distance : 2516778 ft
South Africa
You can check out http://www.glld.fr
- Came across this one and it's added to the bucket list for our setup
2017-1-19
LostinJapan
Japan
Uaviation Posted at 2017-1-18 20:31
Thank you Uaviation
2017-1-19
LostinJapan
Japan
lt Posted at 2017-1-19 08:25
Hi It,
Very nice product!
please could you tell me how do you set up, on UART port or you use additional communication DJI products?
Thx
2017-1-19
lt
South Africa
Hi LostinJapan.
I have no idea at the moment. Just saw it. Think you will probably have to add the RC extension or something. Will investigate when we get closer to purchasing. Maybe you can drop them a mail to enquire.
Rgds
2017-1-20
ricci2
Flight distance : 61158 ft
hi,
The new rc extension for the m600 opens 8 channels configurable by the assistant 2 software with switches and variable potentiometers and shutter option. this should make releasing the hook easy or buy a servo switch that allows low level optical switching (0-5v) to switch up to 2amps and higher voltages. about €5 from hobbyking. I have one to remote switch a second camera on and off.
ricci
2017-1-20
lt
South Africa
Well said Ricci
2017-1-20
fanse2fa4e88
Flight distance : 375761 ft
Alternative to control onboard devices:
2017-1-20
LostinJapan
Japan
Thx Ricci I try to figure out the setup
@fanse2fa4e88  Thxs looks very good
2017-1-20
