jorgerodrigues
Flight distance : 181781 ft
Switzerland
trickn0l0gy Posted at 2017-2-1 03:08
So, finally, I have uploaded my first drone video. There are still some flaws, that I will fix for the next video. E.g. the green line at the bottom is a bug caused by Pinnacle 20 when you use hardware acceleration on export. Also, my gimbal seems to be not 100% horizontally balanced on some of the recordings. Calibration helped with that, but not completely. To be 100% level I have to manually correct gimbal roll by +1.0. Apart from that, maybe increase Bitrate for the videos to get rid of compression artifacts. Also, I plan to get ND/CP filters to help with glare from snow.
Any other suggestions?
Hi there, great to see your video, great footage, specially liked the snow and Zurich images. Just 2 or 3 things I noticed. Be carefull with very long sequences... usually 10 seconds is maximum, unless it's a really, really interesting footage, I usually prefer 6 - 10 seconds max per sequence. After 35 seconds in the video you filmed a really interesting Chinese (??) pavilion, but you just went too fast and then just tilted really hard left. I think (its my opinion of course, and you are free to disagree) it would have been interesting to fly backwards and just let it appear in the image from Under reavealing the beautifull construction. And be carefull with spinning the drone really hard, it's causes vertigo to those seeing the footage, slow is better. I think you should get the snow footage and make one just with that, you had great shots there. Filming from above the skiers is always awesome, and also flying backwards letting the skiers "catch" you, or you catching them. Side footage is also great, just flying the drone sideways, you had this impressive footage at min 2:25, great sense of speed. All in all great footage, a bit long, after 4 minutes is already a really long video for drone footage. Keep them coming ;) |
