DJI A3 ISSUES - HEAVY LIFTER X8 - Voltage Drop
1689 6 2017-1-19
CINEMACOPTER
Costa Rica
Hi Guys, We've been struggling with the new A3. After doing some flight tests, we have huge voltage drops after 3 minute flights. Another weird thing is that when we start the copter, the motors dont start at the same time, it starts 1 per 1 and to have all motors running it takes like 8-10 seconds to be ready for take off.
We send the A3 to DJI for inspection. We thought we will receive a new unit, and unfortunately we got the same unit.
Any suggestions?
We need to solve this ASAP.
Regards
Marco  - Cinemacopter
2017-1-19
DJI-Jamie
Flight distance : 112405 ft
Do you happen to have the RMA number from that evaluation?
2017-1-19
fans8a0cc616
Flight distance : 197831 ft
I run an A2 on an X8 Heavy lift for over a year and it has always started the motors at different times. However not 8-10 seconds apart, more like 4-6 seconds. I believe this is the way the new A3 is set up and is normal. Im basing this off of my A3 on my M600 as it takes about 10 seconds for all 6 motors to get up to speed. I think its just the way its programed. Hope that helps.
2017-1-19
CINEMACOPTER
Costa Rica
The RMA number is CAS-374671-S1H7H3
2017-1-20
SkySight Aerial
Flight distance : 3312018 ft
Since the latest update the motors do start individually. As far as the voltage drop is concerned I don't believe the voltage indicator is right as I get the same thing. I set the warnings as low as possible and even when critical voltage makes the craft land it still shows 3.8 volts per cell on a voltmeter. I can charge my batteries to 25.2 volts and it will only show 24.6 in the go app. I guess this is to build in an element of safety?
2017-1-20
CINEMACOPTER
Costa Rica
Hello everybody. Today we did a new test switching to a wookong flight controller and our X8 worked flawless. Its a shame that the new A3 controller that we receive back from support its defective. I want to recommend everybody to think twice before switching to the new A3 for a professional rig.  I want to see what DJI would do after I have all the videos that proof its not performing well.
DJI I NEED A REPLACEMENT UNIT. This is not fair at all.!
Marco
2017-1-20
AIH
Hello guys
I'm having the same Issue batt voltage drops super fast
2017-1-22
