1345LS Prop Locks
4920 14 2017-1-19
Upthedowns
Flight distance : 288353 ft
DJI have started to push sets of 1345LS prop locks.  These appear to be similar in design to the Inspire 2 mounting plates.  Does anybody know the difference and are these being touted as an upgrade due to a known issue with the durability of the standard Inspire 1 V2 and Pro mounting plates?
2017-1-19
Daroga
Flight distance : 3517287 ft
This is simply DJI changing part numbers within the Inspire 1 series.
The 1345LS prop locks  available at this link -> Click here for the 1345LS Quick Release mounts
were formally called the Inspire 1  1345T Propeller Installation Kit and was previosly available in the store at http://store.dji.com/product/inspire-1345t-propeller-installation-kit
The 1345LS was added to the series with the release of the Inspire 1 V2, Pro, & Raw and supports the 1345T and 1360T Inspire 1 Props...
2017-1-19
Aeromirage
Flight distance : 1778045 ft
I beg to differ.
There is a clear difference, this is not just a part number change.
Check this picture out.....
Compare......
Compare......
2017-1-19
Daroga
Aeromirage Posted at 2017-1-19 19:24
I beg to differ.
Thanks Aeromirage, I stand corrected; the LS kit does have a new base and different upright posts. Thanks for the pictures!!! Looks like the base adds additional locking, requiring a squeeze to unlock.I missed DJI-Mindy's post -> http://forum.dji.com/thread-81140-1-1.html
2017-1-19
RichJ53
Flight distance : 1837356 ft
Daroga Posted at 2017-1-19 17:39
Terry, these mimic the new Inspire 2 style hubs. The offer a metal locking tab the presses into the base. I believe this is a very nice improvement. There was nothing wrong with the original hubs, but this is a nice change. I will be changing out my hubs, they are due for replacement.
All the best
Rich
2017-1-19
Upthedowns
Useful answers guys.  I'm coming up to a maintenance cycle so think I'll make the switch then.
2017-1-20
Daroga
Upthedowns Posted at 2017-1-20 01:22
Agreed and thanks everyone for the updated info!
2017-1-20
skyway
Flight distance : 663 ft
1550T props apparently do not work with 1345LS mounting plate upgrade on I1 ver 1
what are the correct props ?
2017-3-28
Memmi
Flight distance : 324108 ft
performed the upgrade to the LS on a inspire 1 v2.0. Appreciate the locking feature. Any potential for the extra rotational mass to have a nominal impact on performance?
2017-3-29
DJI-Jamie
Flight distance : 112405 ft
skyway Posted at 2017-3-28 09:19
Per the 1345LS mounting plate store link, they support the 1345T/1360T Quick Release Propellers:
http://store.dji.com/product/ins ... -release-propellers
http://store.dji.com/product/ins ... altitude-operations
2017-3-29
fans399d4cc2
Flight distance : 623 ft
I beg to differ.
Can you tell me what the little self stick foam pads are for in the 1345LS mount kits please?
2017-4-27
Nigpd
Flight distance : 597677 ft
fans399d4cc2 Posted at 2017-4-27 10:33
They go inside the prop hub, to allegedly reduce/eliminate the red prop movement phenomenon.
They didn't work for me.  I used a vinyl tape shim to fix the loose red prop issue
2017-4-27
MrSilicon
Flight distance : 6693586 ft
Nigpd Posted at 2017-4-27 12:02
I used a couple thin coats of nail polish. Red locks are rock solid now.
2017-4-28
fans19d83e6c
Flight distance : 28831873 ft
The foam is useless.  It does not stop the prop movement.  I tried thin piece of tape over the hubs, but it was too thick.  Did something similar to what Nigpd suggested. Just put the tape on the bottom section on both sides of the hub and it took care of the issue.  I'll probably cut some neater fitting pieces and use them under all four props, just for balance.
As an aside here, is the blue stuff that comes on the screws enough to hold the mounts on of do you still need to use the liquid screw locker.
2017-5-17
Nigpd
fans19d83e6c Posted at 2017-5-17 13:07
I used the liquid thread lock
2017-5-18
