M600 pro props make a big difference
2539 2 2017-1-20
ricci2
Flight distance : 61158 ft
Greetings,
I have been looking at the difference of the M600 and the M600 pro and as stated by DJI Jamie there is not much to tell them apart.
The damping of the A3 and imu is straight forward but here is a major increase in one aspect. The props on the m600 are 2170 and on the pro its 2195 however the difference in altitude is amazing based on the same motor, 6010.
Max Service Ceiling Above Sea Level
  • 2170R propellers: 2500 m;
  • 2195 propellers: 4500 m
  • Taken from the specs.
Interestingly, the "go app" has a restricted ceiling of only 500m. Do you think the 4500m is a typo or the extra pitch has this much effect, noticed the flying time is down by 5 mins which might have to do with the extra torque, strange as I would have expected extra torque to make the craft more throttle sensitive.
I need to find out how to remove the height restriction on the go app, because I have permission to fly above 2500m for the research work I do with the M600
Just some observations.
ricci
2017-1-20
AlphaBravo
Flight distance : 7356 ft
are the 2195 stronger or thicker blades?
2019-5-9
ricci2
AlphaBravo Posted at 5-9 12:54
Greetings,
They are a bit thicker at the root but its hard to tell really. wish I could be more precise.
ricci
2019-5-10
