DJI N3 gps problem
2762 10 2017-1-20
memo.problem
Russia
hi i have a problem with N3 GPS
2017-1-20
memo.problem
Russia
Tip: The post by the administrator or moderators shield
2017-1-20
DJI-Jamie
Flight distance : 112405 ft
Are you able to reapply the firmware via the Assistant 2? Just to clarify, which Assistant 2 version are you running and could you verify which firmware version you're running? Has restoring to factory settings make any difference?
2017-1-20
memo.problem
Russia
i reapply firmware few times. no changes. i use assistant 1.0.9-2 and older 1.0.5 - no matter .
with 1.0.9-2 i can only flash with N3_FW_V01.07.00.00.bin
2017-1-20
DJI-Jamie
memo.problem Posted at 2017-1-20 22:40
Are you able to upload the flight data to the cloud via the Flight Data section of the Assistant 2 software so that we can try to review some of the flights with the issue?
2017-1-20
memo.problem
Russia
https://www.dropbox.com/s/bf95c71fksgakm6/FLY132.ZIP?dl=0
2017-1-22
memo.problem
Russia
So, any recomendation? for repairing my N3
2017-1-23
memo.problem
Russia
so how i can reset GPS module ?..
2017-1-31
KopterKraft.com
Flight distance : 375761 ft
What is your problem? No GPS at all or not enough satellites?
If you do not see enough satellited, there may be another device disturbing your GPS. Could be a camera or an HDMI cable with unproper shielding,
2017-2-3
memo.problem
Russia
my GPS seen as GPS FROM A3 , not like GPS FROM N3!
2017-2-4
fansc8b00095
Flight distance : 174885 ft
Austria
I have exact the same problem.
Newest firmware V1.7.1.5
How have you solved your problem?
2018-3-30
