too often I get "Gimbal overloaded..." message
1679 18 2017-1-21
flyingasd
Flight distance : 31089 ft
My gimbal:
i never had hard landing, my mavic it's like brand new, but often i get "overloaded problem".
Today I powered on Mavic and everything was ok, few minutes ago I turned it on again and i got overload problem...
no clamps of course.
2017-1-21
madispuk
Flight distance : 133957 ft
Estonia
Have you tried calibrating the gimbal? I had the same problem and just a simple calibration fixed it.
2017-1-21
flyingasd
and now... it works again!
2017-1-21
fans2e9aa3da
Flight distance : 7159 ft
If you have FW 1.3 good luck getting it to calibrate. Seems to be a bug in FW when it comes to the gimbal, overload errors and will not calibrate.
2017-1-21
flyingasd
of course, last fw...
a knowed bug?
2017-1-21
ePetLicensing.c
First of all, you should spread all wings before turning the AC on. Also try elevating the AC so the Gimbal has little bit more space between the floor and the Gimbal and do automatic Gimbal calibration.
Protect animal population. Spay or Neutered and license your Pet!
2017-1-21
flyingasd
@ePetLicensing.c I don't think spreading wings makes difference on initial test.
Gimbal has enough space to move, in fact it has problem only on horizontal axis.
2017-1-21
fansf0572733
Flight distance : 2098566 ft
flyingasd Posted at 2017-1-21 09:31
No, it does not make any difference lol My mavic takes off just fine without unfolding the propellers first
2017-1-21
fans1f4a3127
I have the Same Problem. I use a Samsung Galaxy S6. No crashes or Hard landings. Firmware 1.3.02
2017-1-21
Glad to hear that it works again.
Please fly more and if there's any issue please feel free to let me know.
2017-1-22
Soulhawk
my Mavic is doing this exact same thing except it goes back and forth at least 4 times before it finally stops and then it repeats it again 30-45 seconds later. I tried calibrating the gimbal but i keep getting a failed calibration issue because the camera still keeps moving.
Any suggestions on how to fix this? This only happened when i upgraded the software upgrade.
2017-1-23
flyingasd
DJI Mindy Posted at 2017-1-22 00:43
And again... but now it happens every time.
Firmware : v01.03.0400
i don't think i can update the mavic with the latest firmware with a overloaded gimbal...
2017-3-6
flyingasd Posted at 2017-3-6 00:55
https://youtu.be/CrVTdc-tkCk
Have you tried to do the IMU calibration then do the gimbal calibration?
2017-3-6
hiron81
Flight distance : 1138 ft
Malaysia
if this problem happen always i think you shall send back to dji for warranty
2017-3-6
flyingasd
DJI Mindy Posted at 2017-3-6 03:15
I've just tried to calibrate the IMU and then the gimbal, but nothing to do.
it always shows "gimbal overloaded".
I have also tried to update the latest firmware (01.03.0500) but nothing changed.
so, what do I have to do?
2017-3-6
flyingasd Posted at 2017-3-6 12:22
Since you have tried all basic troubleshooting, I'd suggest you to send it in for further diagnosis and repair. You can get in touch with our tech support at support.eu@dji.com.
2017-3-7
flyingasd
Thanks @DJI Mindy I've just sent a mail with invoice and SN to DJI Support.
2017-3-7
Paul Mansell
I have the same problem with "Gimbal Overload". A quick fix should work if you hold the mavic on its side and start up. The Gimbal settles quickly and no errors shown. Hope it lasts
2018-7-19
Paul Mansell
Further to this though. I think DJI should do the decent thing and "Recall" all drones and fix the problem which clearly is a manufacturer fault. ???
2018-7-19
