RicardoGray
Flight distance : 4356421 ft
FlyingCircles Posted at 2017-1-23 15:04
Yes- I get jitter and flashing when I play back video on my Nvidia Shield K1 Tablet. I am referring to the file that gets recorded on the tablet. The actual video on the drone sdcard look great.
I have a Nivdia also. I do have the extra sd-card also. Mine has always been perfect. Just to be clear, you say you have nothing running that you know of. I went in and removed everything I could and then disabled everything else. Mine is solely used for my Phantom, thus the reason for me doing that. You might be surprised to see what is running in the background. Just because it is not open doesn't mean something might not be robbing the processor. The Go app takes a lot of resources for sure.
Also, if you pick a channel manually instead of "auto". you can adjust you video bitrate down to 4 mb which might help. Few things to consider. Like I said, mine works perfect and I have several friends that I have setup with the Nividia with excellent performance also. Good luck. |
