GB44
Flight distance : 343848 ft
The simulator also lands the aircraft with landing gear up, unless you initiate a Return to home or lower the landing gear manually.
I had one issue in the simulator yesterday where the return to home function worked, but the home point to which the aircraft returned to was not the original home point. Granted you expect a slight tolerance in real world due to GPS deviations etc, but in simulator world I cant see any reason for this. |
