Jason Lane
Flight distance : 260144 ft
Philippines
fans7202207c Posted at 2017-1-23 22:55
I have checked the max hight and it's at 105 meters and it does go that high
When I have tested this rth hight I have never been more than 50 or 60 feet from home point but it does go up to about 30 feet and that's it but it turns flies in re ajust works great just not high enough
"If RTH, including Smart RTH and Low Battery RTH, is triggered between 16 ft and 66 ft (5 m and 20 m) from the home point, and Forward Vision System is activated:
1. If aircraft's current altitude is greater than 32 ft (10 m), the aircraft will return to the home point at the current altitude.
2. If aircraft's current altitude is lower than 32 ft (10 m), the aircraft will first automatically ascend to 32 ft (10 m), from the current altitude.
The flight speed will be adjusted to 9 mph (14 kph). The aircraft will start landing immediately if the Forward Vision System is deactivated. When entering Failsafe RTH, the Forward Vision System status is evaluated and RTH will adapt accordingly" |
