Matrice 600 ... DJI Go 4
2758 6 2017-1-24
P.R
Flight distance : 1135738 ft
I am curious if DJI is considering or working to add the Matrice 600 to the Go App 4 in future??
The M600 is pretty new so it should be in the Go 4 App at some point.
Having to use 2 different Apps when owning their latest Drones is incovenient.
2017-1-24
ricci2
Flight distance : 61158 ft
P.R,
What is this go app4,?
2017-1-24
P.R
ricci2 Posted at 2017-1-24 14:22
P.R,
Thats a new Version of the Go App, but only works for Inspire 2 Phantom 4 Pro and Mavic.
If you check the App store you'll see there are two Go Apps, the 3.xx and 4  we are still using the 3.
But in my opinion the M600 is new as well so it should be in the most recent Go App at some point.
2017-1-24
ricci2
thanks for the info P.R
ricci
2017-1-24
DJI-Jamie
Flight distance : 112405 ft
If the M600 gets transitioned, then the standalone Lightbridge 2 would most likely need to be switched over out of consistency. One of the main points of creating a Go app separation like this was to reduce the processing overhaul on having so many devices supported by one app. I will, though, inquire with the Development team to see if that's being looked into.
2017-1-24
shawn_
Flight distance : 256791 ft
Thanks Jamie, interested to see what is being done. Seems the M600 was never at the forefront of development and has only fallen further behind.
Thanks PR for the post, I'm on the fence about getting an Inspire 2 right now and didn't even realize there was another Go app for it.
2017-1-25
DJI-Jamie
shawn_ Posted at 2017-1-25 07:18
Functionality wise, there isn't a difference between the Go app and the Go 4 app. The only difference is which devices they are able to connect with. At the moment the breakdown is as follows:
DJI Go-
Phantom 3 series (P3P,P3A,P3S,P3 4K)
Inspire 1
Lightbridge 2
Matrice Series (M600, M100)
The first P4
Mavic
OSMO Series (X3, X5/R, Mobile)
DJI Go 4-
The Phantom 4 series (P4, P4P/+)
Mavic
Inspire 2
The Mavic and the P4 are the only 'odd balls' that are able to be used with either app due to the timing of the transition. The only thing is that the Go 4 app would receive more priority updates to add features for those two compared to the Go app. You could still use the Go app for those two if you want, but you wouldn't have access to any new features that may be added with the Go 4. If you're not interested in any of those features, however, then you don't need  to worry about it.
The Go app still receives updates to either add or improve the features to its supported products that are already in place, so it's not necessarily an irrelevant app. There just won't be any new products added to the Go app, and would instead be added to the Go 4 from here on in. so that one app is not siphoning processing power from a device at one go.
2017-1-25
