Augustus Brian
Flight distance : 397592 ft
Mabou2 Posted at 2017-2-16 23:13
Well then.... my friends here who don't think a dedicated button is a good idea... should reconsider. A dedicated button is by-far the best idea. Shutting down the motors by selecting a combination of controls that serve a different purpose, is a terrible user interface. You can practice and commit the stick/button combo to memory all you want, but it still won't be second nature if you are in the middle of an emergency and are experiencing a bit of panic, because it isn't part of your normal routine. No muscle memory.
How about we make your computer abruptly shut down by clicking two oft-used alphabet keys at the same time?... Wouldn't that be silly? Definitely takes more effort to reach over to the power key, click it, then click the Shutdown dialog.
Mabou2:
I really, really hate resuscitating this (insert you own adjective) thread, but:
Your "How About We's" analogies form one huge cornucopia of false equivalency.
Neither computers, nor cars, nor TV's, nor boats, nor video cameras, require emergency shut down operations. Cars do come closest, but the emergencies they engender most often require the brake pedal, not a motor shut down (in fact most modern cars need the engine power for effective power braking, and power steering).
Most household appliance emergencies are handled with the power plug. And/or sometimes flour.
This includes computers. But computers do also offer numerous fail-safe prompts, usually put into place to protect users from themselves. These various "Are You Sure?s" would/could represent a combination stick control, just one stretched out in time (press Delete, read Are You Sure?, press Enter). And Ctl-Alt-Delete reboots the computer, usually from a frozen state. Yet this blatantly obvious combination stick control is not time sensitive---you are able to consider the action indefinitely (issa pretty blue screen, ain't it?) before finally taking it.
Boats -- in an emergency, the steering wheel generally trumps throttle release, unless you have thrust reversing (and even then, it would seem to already form a combo control technique).
But the heart of the matter here is emergency shutdown, not simply turning something off (or on) using a dedicated power switch (which, by the way, both the quad and the remote already have).
So, some real equivalence? :
Missile abort buttons and procedures. Heck, missile launch procedures (and dual key-switches).
Jet pilot emergency seat eject switches. Fire alarms controls (break glass, then push button or pull lever). Power plant emergency cooling procedures. Apollo 13 maneuvering jet controls. Grenade pins? (Pull pin, wait, then throw? Is that a combination stick command? Let's see: Pull pin but don't throw. No, wait: Don't pull pin, just throw it. Yeah, you pretty much gotta do both...)
So, again, I'm not addressing whether or not the P?'s should have a dedicated kill switch (combo is just fine). And I'm not criticizing you personally, just that your comparative analogies fail to qualify as cogent examples. Dedicated power switches and emergency shut down procedures are two different animals. Although the former can be used for the latter in certain cases, that isn't its reason for living.
Can you help me out?
Keep Smiling,
Augustus |
