hallmark007
Flight distance : 9812789 ft
4wd Posted at 2017-1-26 10:19
It's simple enough to do, why not try it.
I'm surprised by the resistance even though I agree the app will tell you if you *must* do it.
Do it correctly then you know where you are.
If you read OP what was recommended to do after firmware update
Ok if you conclude that everything is ok, so You recommend calibration to arrive at the same conclusion .
You also run the risk of needlessly getting a bad calibration .
The pain of not knowing what to do was exceeded only by that of knowing what I had done.”
Yes if you feel something is wrong by all means.
Do it correctly and you know where you are?
There is also a chance you won't do it correctly and you won't know where you are.
(If it's not broke, don't fix it) wise words |
