jrm11
Flight distance : 224577 ft
ProudPinoy Posted at 2017-2-3 11:40
Base is enough for time lapse
I owned the dji extension rod with a tripod, if i will do timelapse with a fully extended rod my time lapse video will have shaking movement, the gimbal becomes unstable with the fully extended extension rod.
Yes, you want a very stable base for time-lapse. An extension rod (or cheap tripod) will be much more prone to movement. Being that the base is so short, it is a better choice for timelapse. Of course, any option is only as stable as the surface you place it on.
I recently did a time-lapse from a highway overpass. My tripod is very stable. What I did not count on was bridge sway. The slight movement of the bridge itself clearly showed up in the video. The day was a little windy, and the effect was heightened each time a truck drove on the overpass. Lesson learned - next time I am shooting from the side of the road. |
