What am I doing wrong?
923 9 2017-1-28
Jake Phantom 3
Flight distance : 2639747 ft
Here's the problem. I can connect my Mavic as long as the switch is set to wi fi. The camera and video will come on. But if I slide the switch over to RC the remote won't connect, just keeps saying connecting, but doesn't. I'm using an iPad mini 2. The only thing I can think of is to connect the iPad to the remote I bought a 12 inch charging cable. I thought this cable would work, or am I wrong. Is a charging cable different from a the cables you'd use for downloads etc.? Any info would be appreciated.
2017-1-28
UltraKD
Flight distance : 8579 ft
you might have to link your remote controller to you mavic again, youtube has plenty of directions on how to do that with your mavic. Good Luck.
2017-1-28
Jake Phantom 3
UltraKD Posted at 2017-1-28 13:53
It's not a linking problem. I have since tried the short cable that plugs into the top left of the remote and it works. The one that doesn't work is plugged into the bottom with a 12inch cable. I'm beginning to think it's not the right cable.
2017-1-28
hallmark007
Flight distance : 9827923 ft
Jake Phantom 3  Posted at 2017-1-28 14:03
Are you plugging into normal USB as in under where your phone goes or to mini USB , because I think you need to plug into normal USB for iPad to connect to RC
2017-1-28
Flybee
Flight distance : 2203983 ft
Sweden
I have the same thing Iphone + Ipad 2 works perfect in the controller connection but a linking cable with USB is not working with non of the above named devices. When you connect via WIFI it should not matter what kind of cable you are using.
Are you sure about the "disconnected" message, when I attached the phone and the normally working connection (with the supplied cables) a little wrong, did't push it all the way in. I got this message in DJI GO app "disconnected" but that was the connection phone/RC. Not RC/AC.
Hope it helps a little bit.
2017-1-28
DaveAus
Flight distance : 100807 ft
If you are using the USB port at the bottom of the remote, make sure you unplug the small cable from the side of the remote. ?
2017-1-28
Jake Phantom 3
DaveAus Posted at 2017-1-28 15:01
Yes, the small cable on the RC side is unplugged.
2017-1-28
Jake Phantom 3
Flybee Posted at 2017-1-28 14:40
It works when connected to wifi, but I don't want to fly wifi. The message says Connecting, it says this for a few minutes and then times out and begins to shut down the remote. This happens when plugged into the USB on the remote bottom.
2017-1-28
Jake Phantom 3
Thanks everyone for the suggestions, I found the problem. It was my short cable, USB to Lightning it was bad cable that didn't work. I replaced it with another and it works fine now.
2017-1-28
HWKIDD
Flight distance : 22877 ft
if you still have a cable plugged in the side port,  when you try to use the usb port it will not work,  make sure the other cable is not plugged into the controller,   if you have done
that,  I would suggest your  delete and redownload  dji go 4,   or maybe try a reboot first,   I am using a mini 4  and had a issue the first use, with a green screen,  and all worked
after reboot,   i used the regular mini cable,  first  and had no issues, with it,  but  if you have a charge only cable, it might be a issue.
2017-1-28
