Geebax
kelvinmorton Posted at 2017-2-20 19:08
I am having similar problems. I have two new 16Gb cards and keep getting a 'capacity error' message. The P4P errors out when I try and format the card using the app. I formatted the card on the PC and also moved a few files back and forth to make sure it works. When I put the card back in the P4P I still get the error message. I'm running an SD Card validation utility on the card now and the first thing I notice is that it an only check 14Gb rather than 16Gb due to the partition, so I may blow away that partition and see if it works after that. This makes me concerned about whether or not the two new Samsung 64Gb cards I have coming in the mail will work!
The Samsung cards will most probably work OK, but to be certain, buy Sandisk Extreme series cards, they are known to work, and always format them in the aircraft.
