visionrouge.net
According to the FCC website, it's the same board,
I'm ordering one 120 g next week and will check as soon as I received it.
First question is to check if the file can be read directly without the DJI reader. As they use their own connector, they may have switch some data pin to inverse and so, writing on a true SSD some corrupted data, only available if you use their connector.
Here will be my test sequence.
-> buy 120 gb Samsung SSD, This is not the EVO, but the EOM version, way cheaper, the board is green, the version 2 is black.
-> use it and write some file on it with the Inspire 2.-> Check the model actually inside, DJI may have upgraded sisn the FCC was filled.
-> open the cinedrive it and read directly from a SATA USB reader the sub SSD included.
IF all is fine, I do not need to buy a DJI reader anymore, first maney saved
-> if not, I need to buy their reader, but that do not mean the switch can't be done, I will only save money on the drive.
-> Buy another 120GB first (I'm not so rich, you can support this project by offering few coffee on my webpage) and try it
If it's working, I will buy a 960GB to test it right away
if, not, I will just have lost 419 rmb(The eom version is there) wich is about 60 USD!!!!
I also quite sure DJI did not
If it's working well, I need to find a way to get the inside SSD to cool down a bit by using some thermal foam each time I'm flying and put a new one inside.
I alsways use a new memory for each flight, losing your drone is one thing, but losing a full day shooting is another, so buyin plenty of 256 SSD (price is 639 rmb, 93 USD) makes a lot of sense. Also, I'm often outside with my UAV and go back later to a computer with a table and electricity, I don't like to upload my footage in the middle of nowhere and risk to break or damage one, so, a nice box with all the SSD awayting the evening is also a great thing.
Please follow my blog and post, I will keep you posted as soon as I have one. As it's Chinese New year, all order to DJI are pending right now..
