Gimbal disconnected
1137 7 2017-2-1
fans5222bb4a
Malaysia
Having some issues with the zenmuse x5r, gimbal seems to be working fine(working on all axis). Just have problems getting video feed from the camera, SD & SSD cards doesn't seem to be reading as well, so I can forget about doing any updates on it(is there any other ways to update the firmware without the sd card?). Anyone out there with solutions for this matter? Cheers
2017-2-1
Birds Eye
Belgium
I'm having the same problem.
2017-2-1
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, is the video feed intermittent or does it not appear at all? What mobile device and Go app version are you using? For the SD and SSD, is this happening while trying to record or is it had to read afterwards?
2017-2-1
DJI-Jamie
Birds Eye Posted at 2017-2-1 12:48
I've responded to you on your own thread.
2017-2-1
fans5222bb4a
Malaysia
does not appear at all. I'm using the dji go app, also tried using litchi, same outcome. As for the sd/ssd, it doesn't even read, so there's no option to write on the cards(to record).
2017-2-1
Timsters
Flight distance : 1762359 ft
same here anyone before i send my x5r in
2017-3-24
Timsters
Timsters Posted at 2017-3-24 18:43
Dji Jamie please any thoughts? My x5r has been working flawlessly until most recent update currently I showing Gimbal disconnected status in the go app  Limited Pam control through controller and no gimbal tab in the app it all, called support what a let down that was, I have many jobs coming up the end of this month I sure need to fix anymore information I'll be happy to give thanks no hard landings no bumps no scratches just seems like I'm missing something thank  no hard landings no bumps no scratches just seems like I'm missing something thank you
2017-3-24
