OSMOPETE
Flight distance : 35118 ft
Hey DJI brains,I'm on my second OSMO after the first one died of major gimbal failure. The new replacement I got does not seem to record audio at all. I've tried both internal and extarnal microphones and yes they are definitely turned on in the DJI Go app, with mic volume turned all the way up to 100, but no audio gets recorded, the microphone is definitely enabled (it is NOT red in the display) but the level meter shows no movement. In fact, when I inspect the MP4 files on the SD card they have no audio stream component at all. I upgared to most recent firmware but still same problem. It is very important for me to have the OSMO record audio because we use it to synchronise video with outboard audio recorded on a separate field recorder.
You can investigate an original OSMO file for yourself here:
https://www.dropbox.com/s/8xa3nf ... 0Take%2001.MP4?dl=0
I'm a full-time freelance commercial video producer and have invested a lot of money in extra batteries, chargers and a z-axis arm plus other OSMO optical accessories, so I really need this to work, I don't want to have to return this one as well.
