Mark The Droner
Flight distance : 2917 ft
Yeah the first problem is because you have the antennas oriented incorrectly. For example, if the AC was 200 meters in front of you, would you tilt the control antenna so you're pointing it at the AC like a rifle? No you wouldn't.
The second problem is what happens sometimes with an intermittent signal. It doesn't get your message to RTH because the message was broken up, but the signal is too strong to RTH on its own. What to do? You could turn off the controller. Then Fail Safe will engage for sure.
Remember that an RTH doesn't work within 20 meters of the home point. Instead it lands wherever it is. So you may have to take control and steer it in a bit as it comes down.
Hope this helps. |
