Loose motor - rattling sound. VIDEO
3304 15 2017-2-2
Dronie.dk
Flight distance : 8077667 ft
Denmark
My front left motor sounds loose and makes a rattling sound when I spin the prop.
It's also the only motor where the prop is loose. I've seen quite a few posts about issues with Inspire 2 props/motors now. Guess this qualifies for a replacement.
Password: i2
2017-2-2
I 2 Fly
Flight distance : 8176 ft
South Africa
Have you tried the suggested remedies? In all probability it is the loose prop causing the noise.  See my issue and video on this.  I fixed it and it seems to be fine.  You only have a loose prop.  Use some foam (see a number of videos on this) and you'd be OK.  That motor should be just fine!
2017-2-2
Mark Guille
Flight distance : 2031818 ft
Jersey
Look like the loose prop problem everyone is complaining about. Swap it for the opposite prop to see if it is making the same noise. Does the "motor" make the noise without the prop fitted? I doubt it is the motor making that noise.
Good luck
Mark G.
2017-2-2
Dronie.dk
Denmark
Adding a piece of double sided tape inside the prop made the rattle go away and the prop fits tight now. Amazing what you must do to fix a $9,000 drone ;-)
2017-2-2
Coigreach
Flight distance : 546014 ft
Dronie.dk Posted at 2017-2-2 09:05
Where my tape went to temp fix. STILL waiting for DJI to acknowlege this and give me "version 2" red props
temp fix
temp fix
2017-2-2
Cougar1
Flight distance : 924393 ft
Coigreach Posted at 2017-2-2 10:54
Maybe it would be better to place the tape on top of the propeller so the base is resting level instead. By putting the tape on the base, it is resting only on the tape rather then whole base?
2017-2-2
Coigreach
Cougar1 Posted at 2017-2-2 11:07
Maybe better if DJI just replaced these loose fitting props with the correct fitting ones. It's alot of $$$$ in the air to be messing around with.
I only put the tape there to see where the movement was coming from and had no intentions of flying it until it is fixed properly.
2017-2-2
fansa7e34cd9
Flight distance : 2538474 ft
has anyone actually measured the props to see if there is an obvious tolerance problem which given its always the red props looks like there might be a tolerance issue with them ?
2017-2-2
Coigreach
fansa7e34cd9 Posted at 2017-2-2 11:24
Yes! does not make any sence measurements are all over the place
Front Red motor mount
Rear Red Motor mount
Spare Red Motor mount
2017-2-2
Dronie.dk
Denmark
Coigreach Posted at 2017-2-2 11:39
Chinese don't have a word for "Quality Control"
2017-2-2
Cougar1
These measurements has nothing to do with the issue, the play is axial between the propeller and the hub.
2017-2-2
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, does the opposite motor rattle when you swap the two red props? Have you contacted the European Support team?
2017-2-2
Dr Jon
Flight distance : 463012 ft
China
Its exactly the same problem that i had on 9th January and many other since. Its a tolerance issue caused in manufacture. DJI are aware and are sending out replacement props with a simple mod as a short term fix, in the longer term revised design and "free  issue" I hope to us first adopters.
If you want to see the fix take a look at the thread "red Props Rattle"
2017-2-2
Dronie.dk
Denmark
DJI-Jamie Posted at 2017-2-2 22:11
I did on tuesday - Sadly they haven't bothered to answer me yet.
2017-2-3
DJI-Jamie
Dronie.dk Posted at 2017-2-3 05:36
Could you happen to supply the ticket number that would have been generated when you contacted them?
2017-2-3
Dr Jon
China
Dronie.dk Posted at 2017-2-2 12:50
yes they do its....
zhi liang kong zhi
2017-2-3
