X5S in pictures, to fix in next firmware
937 1 2017-2-2
visionrouge.net
I have noticed few software issue with the X5S in Photo mode. If someone from DJI can have a look...
-> The Amount of pictures to take per shutter buton is always reset to 1 when restarting the aircraft, all other parameters are saved
-> During the time a picture is saved, all parameters can be adjusted and immediatly displayed except aperture. the aperture display change on screen, but the lens do not change its actual aperture. I need to wait the picture to be finished saved to get again a working aperture.
-> serioulsy guys, can you add an option about warning message and the way the pop up every 5 second if we flight by low light...?
Or a way to disable these about object avoidance.
But for the rest, this is an amazing bird...
2017-2-2
Spiky247
Flight distance : 455459 ft
May I also suggest adding a feature where you can use the custom function to switch the camera into a vertical orientation for shooting photos?
2017-2-4
