allanart
Flight distance : 1050577 ft
The package of replacement props and quick-lock connectors arrived earlier today.
I started by installing one of the two new Red quick-locks which worked perfectly – giving a nice firm fit with no play.
On the strength of this success I installed the second new Red quick-lock, which while giving a small improvement, still resulted in excessive play in the prop.
I then carefully examined the components of the quick-locks and found the problem to be with the Red outer locking ring - exactly as suggested above.
I proceeded to use the Red inner post with one of the White outer locking rings and found this to be a perfect solution.
Now ALL the Red props fit correctly – including the original set with no foam insert.
The problem is clearly with the Red outer locking rings, not the propellers.
I have simply scraped the white paint marks off the outer locking rings and used them on the Red inner posts.
Just a drop of Red paint is required to complete the job!
It seems very odd to me that DJI have not figured this out – it’s a bit worrying really!
Regards.
Allan
