Geebax
CyFA Posted at 2017-2-9 22:06
Thank you all for your replies!
Need to clear something here. I have been flying for years and among other owned the P2, P3P and now the P4Pro.
Now, as mentioned previously, i had downgraded, upgraded, performed all calibrations with the same SD and so I took it out yesterday for a test.
I have two suggestions, the first is to format your SD card in the aircraft after you copy off the photos and videos, then you start with a clean slate every time.
The second is to get another SD card. I have never heard of a Netac brand card and would be thoroughly suspicious of it. Yes, I know you said it works in your Osmo, but that does not always guarantee it will work in the Phantom 4, it places more demands on the card than the Osmo does. Try a Sandisk Extreme series card, if that does not solve your problem I would be surprised.
From what I am able to determine, there is no buffer capacity in the DJI aircraft's video processing system, so if a card cannot keep up in terms of sustained write speed, it just simply stops recording, and that would adequately explain what you have described here.
