BuzzCut
DJI-Ken Posted at 2017-2-7 08:51
The props for the prop cage are a little smaller so the standard cage will not fit with the standard props.
You've been flying without a cage since you've had the Mavic, so you use those props while flying outdoors. And for close proximity flying, you would use the new stuff.
I guess this is the maximum safety approach. If the cage was designed to work with the current props I'm guessing it would interfere with the camera image due to the size.
There are other solutions out there that don't cover the props 360 degrees and work with the existing props, but I think this is about the safest thing one could design, which would be great for realtors, those potentially photographing people (e.g. weddings) etc.
Seems like a good addition to what's already out there. |
