Kneepuck
Flight distance : 275105 ft
My Hdmi module worked for about 5 or 6 months, then gradually began having intermittent connection issues with both devices it worked fine with before, then would not connect ever again. The interesting thing is, it also would not connect to my Standard, which connects through wifi only. If I remove just the HDMI section of the module, the usb portion works as normal, and connects to my Phantoms including the P3S, using either device. So it seems the problem is isolated to the Hdmi section of the module, yet still affects the connectivity of the wifi as well as the usb to device connection. Strange. I also use an Nvidia Shield, which has an Hdmi output, but my purpose was to be able to use 2 sets of goggles at once, which I can not do without a working Hdmi module on the remote.
