cluc
Flight distance : 85682 ft
Every flight is recorded on the aircraft and controller, regardless of having the DJI Go App running.- They can always be extracted, by following DJI's flight log extraction tutorials.
Warranty is only voided if after investigation, it is identified that the Litchi app caused the issue.
- I'm pretty sure there was a post by DJI Ken a while back responding to the exact same question. (Too bad the search function isn't that good here)
- Basically if it was a malfunction on it's own, e.g. motor failiure and there were no obstructions to it, then you are covered by the warranty, even if you are using Litchi. However, if you are using the Litchi App setting up waypoints and for some reason, the aircraft goes and does it's own exploration and hits a tree, then your warranty will not cover that, as you were using Litchi App.
Hope that helps.
@DJI Ken, if you are able to find that post, please send through the link or correct me if my understanding is incorrect.
