ricci2
Flight distance : 61158 ft
Hi All,
M600 on a routine test flight, I thought I would do a full systems chk, all was well when I pressed the Auto land button, aborted a metre from the ground then lifted to 10m then pressed the home button. It tried to land where it was, just descended. So aborted and lifted to 10m again and pressed the "H" on the controller and it just said it's landing and just descended where it was.
So looked at the sliders in the configuration to see if all were turned on and green, yes, looked at the altitude and it was set to 25m as normal, I have all the latest updates however there was an update for the go app followed by another a day later and this has happened between flights due to inclement weather.
I will chk the logs later.
Has anybody tried a RTH since the last go app update?
If anybody has a flight planned could they please do a RTH and see if it's a universal issue or just me, be prepaired for it to land where it is so have a flat area to test on please.
Thanks
Ricci
