X5R FullHD Problem
1231 7 2017-2-8
240RYU
Flight distance : 841900 ft
Japan
Hello everyone! I'm contacting from japan.
Now, I'm wondering that X5R camera has some problems, i think.
Plese someone help me. By the way, if my english is wrong, please ignore that.
Shooting at X5R.
SSD and SDcard setting were 1920×1080 60fps.And,D-Sinelike.
The problem is, when setting FullHD for DNG RAW, the movie wasn't looks like FullHD.
DNG RAW looks less than FullHD.
And chaecked a movie in SDcard,it seemed FullHD.
There is clearly difference for movie quality between SSD and SDcard.
Is this DJI problem or my problem? Of course, I verifyed this problem, used another X5R camera and SSD, for same setting.
But it was same result.
Please someone answer this problem.Thank You.
2017-2-8
DJI-Jamie
Flight distance : 112405 ft
Is there any way for you to provide some samples via Dropbox?
2017-2-10
240RYU
Japan
DJI-Jamie Posted at 2017-2-10 20:24
Yes,I can.Where should I send?
2017-2-13
DJI-Jamie
240RYU Posted at 2017-2-13 16:22
You can post the Dropbox link here.
2017-2-13
240RYU
Japan
DJI-Jamie Posted at 2017-2-13 22:50
Sorry for delay.This is the Dropbox link.
Please check it, and tell me that is normal thing or not.
https://www.dropbox.com/sh/v9en1 ... 5wj4ACQdh5nvfa?dl=0
2017-3-7
iSkyUnmannedSys
Flight distance : 7152087 ft
Hi,
The H.264 files which are recorded on the SD are based on what setting you change in the GO app. So if you set saturation/contrast/sharness or set a colour space such as D-LOG then the H.264 files will be encoded with them settings onto the SD card.
The DNG files on the SSD are not effected by these setting as they are not processed. They are simply DNG still images directly off the sensor. You have to process these DNG files through either Cinelight (which I wouldn't recommend) or Devinci Resolve or Premier Pro. You can then add sharpness. colour correction using these programs.
2017-3-7
240RYU
Japan
iSkyUnmannedSys Posted at 2017-3-7 06:49
Hi,
Thank you for your reply.
2017-3-16
240RYU
Japan
Hi,
2017-3-16
