Video Issue
1142 13 2017-2-9
Ant2596
Anybody know the cause of this video issue? It is visible in the video in the link below, clips at 26, 31, and 34 seconds. The water is not being displayed accurately. I have this issue on a few shots, usually with lots of detail (water, roofs, etc). I filmed this with the X3 on the Inspire 1 V2.0 at 1080/24 fps (I believe). I also imported the footage into Final Cut Pro 7 and exported as a .mov for smoother playback in Final Cut.
Thank you,
Anthony
- Link
2017-2-9
DJI-Jamie
Flight distance : 112405 ft
Do you see this with any other resolution? Did you happen to notice this after a firmware update or a hard landing?
2017-2-9
RichJ53
Flight distance : 1837356 ft
Hard to say for sure, what brand and speed is your SD card? I use the SanDisk U3 Extreme plus 64gig chips with good results.    link
I always try to film in the highest resolution and if needed it can be downgraded in post.  Fun action shots for sure.....
All the best
Rich
2017-2-9
Mark Guille
Flight distance : 2031818 ft
Jersey
Hi Anthony,
Were you using an ND filter for these shots?
Mark G.
2017-2-10
Ant2596
Mark Guille Posted at 2017-2-10 06:43
Hi Anthony,
I was not using an ND Filter for these shots
2017-2-14
Ant2596
DJI-Jamie Posted at 2017-2-9 16:05
I've noticed it with all resolution and formats that I film in. I have not had any hard landings and noticed it before i made any firmware updates
2017-2-14
Mark Guille
Jersey
Ant2596 Posted at 2017-2-14 08:34
The next time you shoot in that sort of light, I would try an ND 16 or at least an 8 to get your shutter speed to around the 1/50 sec mark, I think you will be surprised the difference it makes.
Mark G.
2017-2-14
Ant2596
Mark Guille Posted at 2017-2-14 08:51
Mark G.
Got it, Thanks Mark.
2017-2-14
DJI-Jamie
Ant2596 Posted at 2017-2-14 08:36
For the most part, it looks like anti-aliasing. There might not be much that can be done about that. The exposure to the light could be making it more apparent, I would recommend trying Mark's advice to see if it helps.
2017-2-15
Ant2596
DJI-Jamie Posted at 2017-2-15 22:30
Do you think I should get better with results by using the Z3 Zenmuse camera? I've been using the X5, but also own the Z3.
2017-2-25
Ant2596
Ant2596 Posted at 2017-2-25 04:27
Ive been using the X3, not X5.
2017-2-25
DJI-Jamie
Ant2596 Posted at 2017-2-25 08:44
Anti aliasing may still be there, but not as much in comparison. Have you seen any difference when using the Z3?
2017-2-25
Ant2596
DJI-Jamie Posted at 2017-2-25 10:52
I haven't noticed it yet but I also haven't used it as much.
2017-2-25
DJI-Jamie
Ant2596 Posted at 2017-2-25 12:12
You should see a difference whenever you have the chance to use it.
2017-2-25
