Not sure if this has happened to anyone, but I had a weird experience flying recently. My drone spontaneously came back to life after shut down. It became a phantom Phantom! I landed and the engines shut down completely. After a pause to remove my phone from the clip, I then turned off the remote and the drone sprang back to life and lanunched on its own. It only went up a couple meters, but started drifting dangerously toward obstacles nearby. I rushed to turn on the remote again and seemed to regain control after about a second or so. I mananged to make it land, but it did so really awkwardly, falling on one side and scraping the ground briefly with its props. Anyway, I finally shut it off and the next flight went without issue. Anyone had anything like this happen?
FuZZyPiLOT Posted at 2017-2-10 03:24
It seems very foggy on the video, so lots of moisture in the air, probably not doing the Phantom any favors.
Would you have accidentally hit a button when removing the phone from the holder?
Hadn't thought about humidity. There's plenty of it in this climate. However, I keep most of my electronics stored in dry boxes and the drone is quite new. I am wondering if I somehow hit auto launch on my phone, but it didn't seem to launch until I turned off the remote. I could be wrong about this, though. I hope it is just some kind of operator error.
There used to be a risk of this kind of thing back in the old days. If you placed your phantom on the ground and started it up without turning on your RC first, there was a risk that the AC will boot up, realize it doesn't have a control signal, and begin RTH when it thinks the home point is over 20 meters away. Or if you landed more than 20 meters from your home point and stopped the motors and turned off your RC but left the AC on, it would go into RTH. I haven't heard of this happening lately so I assume DJI did something to the more modern Phantoms to stop this.
It may show in the flight record if you accidentally hit the auto take off, though that requires you to operate a slider as well, at least on the recent versions
There used to be a big risk of this back in the old days. If you placed your phantom on the ground and started it up without turning on your RC first, there was a risk that the AC will boot up, realize it doesn't have a control signal, and begin RTH. I haven't heard of this happening lately so I assume DJI did something to the more modern Phantoms to stop this.
I was flying P3 standard. It didn't seem to do RTH, just sort of drift out of control. If no one else reports this kind of thing, I'll dismiss it as an anomaly. I've started turning off the battery before turning off the controller or leaving the app, though.
" I landed and the engines shut down completely. After a pause to remove my phone from the clip, I then turned off the remote and the drone sprang back to life and lanunched on its own. "
No great mystery there. There have been many similar reports.
Your Phantom lost signal because you switched off the controller while you had left teh Phantom on.
It was attempting to RTH.
Don't leave your Phantom sitting powered on and don't switch the controller off first.
Labroides Posted at 2017-2-10 05:08
Ok, it kind of confirms my hypothesis. I've since been turning off the drone battery first before remote and/or APP. Lesson learned without lost or damaged drone. I'll take it.
It was because you turned off the transmitter before turning off the aircraft.
Power on: Transmitter then Aircraft.
Power off: Aircraft then Transmitter.
