P.R
Flight distance : 1135738 ft
there is ceartenly no battery problem, as you rouled that out by your testing. the xt30 output should get the power from All batteries equally. Please check the voltage and see if there are dicrepancies and post it here, as % values are not very reliable.
Then hook up the m600 to the assistant and connect gimbal and everything, then in the battery tab you can see the power draw feom every battery, see if less power gets out of the #3 battery.
Do you get a Battery voltage warning on the app?
It could be a fw issue, try to downgrade and see what happens, and have you deep cylcled your batteries? Maybe the software has some problems to recognize % of the battery.
Next could be and i hope not, and correct me when im wrong, maybe one motor is drawing less power then the others and that one is getting less power from #3 battery, could you test with a thermal camera and see if motor #3 or #4 is colder then the rest? I may be wrong on how the power managing system works. |
