DJI-Jamie
Flight distance : 112405 ft
Hazardpro1 Posted at 2017-4-25 00:23
Hi Jamie
Got the camera working in the end - seems I had 2 separate issues, faulty Matrice mount kit and LB2 unit (or at least swapping them for new ones fixes the issue).
Just to clarify, is the LB2 air end up to date as well? For the air side, there isn't a reset to factory defaults available. For the LB2 ground end, you can perform the following button combination to reset it of any odd presets that could be affecting the unit:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
When connecting the X3 to either the OSMO or the aircraft, could you verify if the camera firmware reads as v1.10.1.40? |
