Panasonic Zoom Lenses
3116 13 2017-2-13
Octavian
Flight distance : 56158 ft
Can somebody give some details how DJI X5S works with Panasonic Lumix 14-42mm/3.5-5.6 HD ?
I want to buy those lenses and I'm curious if you can zoom while you fly. Also those are parfocal lenses? Some are saying yes others no. And the most important thing: if you look on the net you will see different lenses with the same name Panasonic Lumix 14-42mm/3.5-5.6 HD. I wonder if this are the right one https://www.bhphotovideo.com/bnh ... s=REG&A=details
2017-2-13
Daroga
Flight distance : 3517287 ft
Reported to work perfectly. Take a look in RCGroups beginning with this thread and a few replies:
Click here to view Arrow1969's post. Then click the upper right corner link to read further...
2017-2-13
Octavian
Daroga Posted at 2017-2-13 16:31
Are the same lenses like in my link?
2017-2-13
Daroga
Octavian Posted at 2017-2-13 17:55
He bought his here -> Click here to see the CVP site
2017-2-13
Arrow1969
Flight distance : 400577 ft
I have only manage to do a couple quick tests on the Panasonic 14-42mm f3.5-5.6 Lumix Lens useing a X5S and DJI Inspire 2 see video's due to the weather in the UK a the moment.
2017-2-13
DJI-Jamie
Flight distance : 112405 ft
As others have mentioned, that lens would work fine.
2017-2-13
aviscomi
This entire compatible lenses thing has me thoroughly confused.  Some say certain lenses will work, some say they won't.  Then there's the whole lens balancing, with ring, without ring, with filter, without filter.  OMG!  It would be ideal if there was 1 concise table that contained all the pertinent information in regards to lenses & balancing.
2017-2-14
Coigreach
Flight distance : 546014 ft
aviscomi Posted at 2017-2-14 05:10
Yeah it would be nice to have it all slapped down in front of you so you can just tick buy now!
Then again sometime researching can be quite therapeutic.
DJI 15mm lens weight is approx 115grams/ 4.1 oz  what you need to look for is a lens that come close to this weight. if its under weight then you might need to add a filter / balance ring. If its over weight (and obviously dependant on how much over weight it is) you need to counter weight the back of the camera and depending on that counter weight you might also have to put on a side counter weight.
Take for example the Panasonic : LUMIX G VARIO 14-42mm F3.5-5.6 II ASPH. MEGA O.I.S.  See link https://www.amazon.com/Panasonic ... eable/dp/B00B7FOVAM
This is 110 grams so only 5 grams out so maybe a lens hood/ filter? to get it spot on!
where as the Panasonic : LUMIX G VARIO 14-45mm F3.5-5.6 ASPH. MEGA O.I.S.  see link https://www.amazon.com/PANASONIC-14-45mm-F3-5-5-6-Mirrorless-H-FS014045/dp/B002IKLJV4
This is 195 grams (80 grams over weight) you would then need to counter balance with weights at the back of the camera and depending on where you placed the weight would determin how much weight to add to the side to even it all out.
One other thing to watch out for is max diameter of the lens the X5 can only take up to about 60mm the X5S can take up to about 65mm.
I do have the Olympus 14-42mm but I think I will be doing a bit more research into primes as I belive you get better quality and value in glass! which is better in the long run.
hope this get you off in the right direction and selection.
P.S. I used Panasonic as examples only (I don't like these lenses) but each to their own.
Karl
2017-2-14
Daroga
Thus far, eight lenses have been approved by DJI. ->
Click here and then scroll down to view the compatible lenses table shown below:
Your balancing rings are available in the DJI Store ->
Click here to view the balancing rings available at the DJI Store.
Array of compatible lenses
Since it uses a standard Micro 4/3 mount, the Zenmuse X5S now supports up to eight professional lenses*
with focal lengths ranging from 9mm-45mm (equivalent to 18mm-90mm on a 35mm camera),
providing more creative control over the final look of a shot.
  • Olympus M.Zuiko 12mm/2.0*
  • DJI MFT 15mm/1.7 ASPH
  • Olympus M.Zuiko 17mm/1.8*
  • Panasonic Lumix 15mm/1.7
  • Olympus M.Zuiko 25mm/1.8*
  • Panasonic Lumix 14-42mm/3.5-5.6 HD*
  • Olympus M.Zuiko 45mm/1.8*
  • Olympus M.Zuiko 9-18mm/4.0-5.6*
*A balancing ring is needed for some lenses,
More compatible lenses will be available.
2017-2-14
Coigreach
Daroga Posted at 2017-2-14 11:02
  • Olympus M.Zuiko 12mm/2.0*                    Weight = 130g / 4.6 oz.
  • DJI MFT 15mm/1.7 ASPH                          Weight = 115g / 4.1oz
  • Olympus M.Zuiko 17mm/1.8*                   Weight = 120g / 4. 2oz.
  • Panasonic Lumix 15mm/1.7  or                 Panasonic : LEICA DG SUMMILUX 15mm F1.7 ASPH.   Weight = 115g / 4.06 oz.
  • Olympus M.Zuiko 25mm/1.8*                   Weight = 137g / 4.8 oz.
  • Panasonic Lumix 14-42mm/3.5-5.6 HD*    Panasonic : LUMIX G VARIO 14-42mm F3.5-5.6 ASPH. MEGA O.I.S.     Weight = 165g / 5.82 oz.
  • Olympus M.Zuiko 45mm/1.8*                  Weight = 116g / 4.1 oz.
  • Olympus M.Zuiko 9-18mm/4.0-5.6*          Weight = 155g / 5.5 oz.
what I've found out so far. nothing under weight but a few that will need a bit of counter weighting.
2017-2-14
aviscomi
Thanks, wasn't quite expecting all that.  Also note that I've been doing research on lenses & balancing, but just when I think I have it figured out someone posts a conflicting configuration.  Hell, I have "wishlists" on B&H and Amazon filled.
2017-2-14
Daroga
Coigreach Posted at 2017-2-14 11:28Olympus M.Zuiko 12mm/2.0*                    Weight = 130g / 4.6 oz.DJI MFT 15mm/1.7 ASPH                          Weight = 115g / 4.1ozOlympus M.Zuiko 17mm/1.8*                    Weight = 120g / 4. 2oz.
In case it wasn't clear,
there are balancing rings (and depending on the lens, counter-weights or lens hoods) available at the
DJI Store for each lenses with an * next to them.
2017-2-14
Octavian
This lenses are only 95 grams https://www.bhphotovideo.com/bnh ... s=REG&A=details
2017-2-14
Octavian
  • This lenses are 95g https://www.bhphotovideo.com/bnh ... s=REG&A=details
    2017-2-14
