N3 Flight Controller Firmware Version : 1.7.0.0
I don't have the exact version for the iOSD Mini, but as long as you use the V4.1 version of the iOSD Assistant Software, the latest version for both iOSDs would be there in the INFO tab.
hi, I tried connecting the Mini iOSD to the N3 but the plug are different. The N3 came with a CAN Gimbal cable that has the same connection as the IOSD plug. Should that cable be connected on the female port of the iOSD?
djiuser_Y39sUK8 Posted at 2017-9-26 06:48
DJI-Mark Posted at 2017-9-26 06:58
Please refer to the installation guideline on page 14 regarding this point: http://dl.djicdn.com/downloads/N3/20170825/N3_User_Manual_En_v1.4.pdf
Thank you for the manual, but it doesn't say or explain about the mini iOSD connection. Im guessing the Mark 2 has to be used?
djiuser_Y39sUK8 Posted at 2017-9-26 08:26
Those devices are older so perhaps there is an adaptive cable. The N 3 does talk about compatibility with the Mini iOSD and the Mark 2. Unfortunately there is not any additional information on this point.
DJI-Mark Posted at 2017-9-26 08:35
hi, so the best way to use the n3 is for the Lightbridge 2 and the x3 camera?
