How large tablet can you fit on the mount?
10012 22 2017-2-15
ErikL
Sweden
Hi!
As the topic says, how big tablet can you fit on the controller mount?
Is it possible with a ipad air or have does it have to be a ipad mini?
/Erik
2017-2-15
Geebax
The mount is just big enough to take an iPad Air 2, anything larger would require a modification to the mount.
2017-2-15
Punchbuggy
Flight distance : 483166 ft
I'll assume from your post that you have an Apple tablet in mind. Just saying that there are 10.1" android tablets on the market which fit. It's all in the screen ratio...
2017-2-15
DJI-Jamie
Flight distance : 112405 ft
Punchbuggy Posted at 2017-2-15 22:59
It's about a 6'' maximum width requirement for the tablet to fit in the device holder without modification.
2017-2-15
RedHotPoker
Flight distance : 165105 ft
I'm also using an iPad Air2 Cellular. It's a pure delight. Fits the OEM device holder just perfect and gives awesome visual clarity of all the Go app parameters. Surprisingly, for it's larger size, it's not too heavy for my uses. Even after flying four consecutive flight packs. It performs flawlessly and doesn't heat up, unlike my original choice, an iPad Mini that I had purchased early on, in my Phantom 3 Pro' adventures.
Advise buying the Inspire device holder or reasonable facsimile with the metal base, as it's much more solid, and doesn't wobble like the original on my RC did.
RedHotPoker
2017-2-15
Propwash
Flight distance : 13058 ft
RedHotPoker Posted at 2017-2-15 23:19
Hi RHP try this for stability
Needed this to give my tab S 10.5 stability which just fits the device holder with the removal of the sponge cushion on the lower jaw
2017-2-16
24ctDrone
Get an extender,  I use a iPad Pro and its badass!
2017-2-16
RedHotPoker
My DJI Inspire device holder has been on my RC for two years, and I've only had to tighten the hinge screw once, never a problem.
It holds my iPad Air2 Cellular tight and safe.
I would recommend it to anyone who wants a great device holder.
RedHotPoker
2017-2-16
Propwash
RedHotPoker Posted at 2017-2-16 22:26
This  works with the inspire device holder increases the stability
2017-2-16
Propwash
24ctDrone Posted at 2017-2-16 22:23
No need of one
2017-2-16
RedHotPoker
Propwash Posted at 2017-2-16 22:48
It looks quite bulky and oversized. Not sure that it would fit in my Nanuk 945 or DJI hardshell backpack without doing some cutting and carving of the foam interior? But as I said, it's not necessary with the sturdy tight Inspire device holder. Mine works like a charm.
RedHotPoker
2017-2-16
DJI-Jamie
I would agree that it's 9.7'' counterpart would do the trick, since its the same A9 processor anyway.
2017-2-16
RedHotPoker
DJI-Jamie Posted at 2017-2-16 23:47
Correct me if I'm mistaken.
I think he was referring to not needing to use an extender for the device holder, not the device itself. ;-)
RedHotPoker
2017-2-17
DJI-Jamie
RedHotPoker Posted at 2017-2-17 00:40
You're probably right, it was most likely a 'too quick of a read' on my part.
2017-2-17
RedHotPoker
DJI-Jamie Posted at 2017-2-17 10:56
Too many thoughts at one time... We all experience that.
You are keeping far too busy on several fronts, and it can get confusing at times.
Thinking way ahead of ourselves.  We can sometimes miss the minor details.
I used to call that the brilliant professor syndrome. ;-)
Similar to the Disney production, Absent Minded Professor, but without the flubber. Haha
RedHotPoker
2017-2-17
Aardvark
Flight distance : 384432 ft
I use the iPad pro 9.7 and it's made to measure 2 clicks on the ratchet clamp and its solid as a rock in the standard P4 holder (metal bracket). The P4Pro might have similar metal bracket.
2017-2-17
RedHotPoker
Aardvark Posted at 2017-2-17 11:57
Similar to my iPad Air2, two clicks and you're good to go, flying. ;-)
Yes, the metal base has all the stability adding to the safety and stability.
RedHotPoker
2017-2-17
Aardvark
RedHotPoker Posted at 2017-2-17 12:09
Yes they're the same dimensions, when the 9.7 pro first came out I went to a national computer store and asked for a case, they of course didn't have any specifically for the Pro but had a good selection for the air2. There were a lot of 'Oooohs' & 'Ahhhs' and 'don't knows' from the 'experts' (Fake News from them) when I picked a nice one for my device. And it fitted perfectly (alternative fact (not))
2017-2-17
Picmaickel
Ive got the ipad2. And its to big. But u can buy an aditional mount for the controller that fits bigger tablets. I use RAMMount on a tripod. Works better for me!
2017-2-17
RedHotPoker
Aardvark Posted at 2017-2-17 13:07
Oh by the way, the Donald has changed that definition.
Now it's called really fake news.. Hahaha
It became evident in yesterday's unexpected news conference. ;-)
No yes, really.. Ha
RedHotPoker
2017-2-17
Grizz 1
Flight distance : 120066 ft
my ipad pro 9.7 fits the original holder in both my P4 and the P4 Pro without the adapter.
2017-2-17
fans980a1579
Flight distance : 4039862 ft
Grizz 1 Posted at 2017-2-17 15:36
Just got a new iPad 6th gen 9.7".
Want to put a case on it. will it still fit in the bracket of the P4P with a case?
What is the max depth of the bracket? Or another way - what is the max thickness of tablet & case it will hold?
Looking at this case:
https://www.amazon.com/Metropoli ... Pad+6th+gen+9.7#Ask
and the depth of the pad & case is 19mm
2018-5-9
Kobski
Flight distance : 1788297 ft
I use Samsung Tab A 10.5 if that's anything to go by
2018-5-9
