Electro-Nick
Flight distance : 7083891 ft
In free mode you can freely yaw and tilt the camera, in follow mode it follows the aircraft movements. Reset will quickly reset the lens yaw to face forward (it doesn't affect the tilt of the lens).
If you want to offset the camera, but follow the aircraft's path, then first set the position in free mode and then switch to follow mode (without going via reset) and fly your route.
You can also set one if the rear C buttons on your controller to switch through the gimbal modes so you don't have to touch the screen.
