fanse186c04e
Flight distance : 26170253 ft
Donnie Stugots Posted at 2017-2-17 09:21
Vince , are you flying line of sight , where I Know you can't see the aircraft with the naked eye but if there was a laser beam between them would it be broken ? I find if I have enough altitude where the AC and RC can "see" one another I get tremendous range , also make sure the aircraft is orientated with the Nose OR Tail of the aircraft Pointing directly back to the Home point . If the aircraft is Yawing the antennas on the front and back of the Aircraft are no longer pointing directly back to the RC transmitter and you will loose range BIG TIME , Just please try this .
You should be getting at least a kilometer of range with your system IF you have the Line of sight I referred to earlier. I Get over 4.5 kilometers on My Inspire I with good weather conditions and If I am line Of sight with the Aircraft . I of course am in the desert or Over water when I do these test, so I am in pretty rural areas to say the least. but I get get two miles easy over rural areas not to far from the city .
thanks Donnie,
I did that before and no good reception .
Today..... i did go 3,3 Km, i think i could do even more, yessss, so i think the day's i did that, the wetter or sun was not friendly with me.
Today, works perfect, happy to know, not that i fly that far often.
I must say i can still see the aircraft when he is 3,3 Km away, the problem is when you take your eyes off and try to look again than the problem to find him starts,.
Even than try to look "slow", i do not know a other way to explain, and when you look slow and focus i will see it every time.
I am very happy now to know that the distance is ok, so, till now everything is tip top and unbelievable great.
Again, it looks like the Inspire pro, bud thats all, it looks like it, bud it's really a different machine when it comes to flying, so presise and so good to handel, i can make even more complex shots now, like i already did.
The great thing is that you really can make shots now that trow the jibs an rails from the stage, so great.
Real real great.
Yes i know my english is not that good :-) :-)
Again thanks Donnie,
Greatings,
Vince |
