DroneFlying
Flight distance : 10774613 ft
ClancyO Posted at 2017-2-20 15:55
This all seems a little crazy to me...I seriously doubt that DJI is popping these out of a fridge before the initial factory IMU calibration. Now I'm afraid to even try this.
Nobody ever said that DJI uses a refrigerator. Here's what one DJI employee (Natalia) said about it, though:
"A Thermometer detects aircraft temperature and, over time, changes in aircraft temperature. Each time you turn on your drone, the IMU needs to warm up to the temperature at which you last calibrated. For example, if you calibrate the IMU at room temperature, the next time when you start the drone, it needs to warm up to room temperature before its ready to fly. Sometimes pilots get frustrated if their IMU takes too long to warm up. The drone may be taking a while because the IMU was last calibrated at a relatively high temperature. This is why we often recommend calibrating while your drone is cooled down. For example, trying placing it near an AC vent or unit before calibration."
And another:
"The IMU is calibrated at the factory in a controlled environment to allow for quick start up."
So no, not "crazy".
