DRONE-flies-YOU
Flight distance : 1450594 ft
Flybee Posted at 2017-2-19 00:54
I just checked the "flight records" from the device (cellphone) and when I stopped Cinematic it switched to GPS but still had this effect. It was not responding (or at least not accurately) so it took some more seconds to land it. I read somewhere (in this forum) that the RC is working like in hydraulic mode for a while so you have to move to sticks a lot until it is back to fully working as it should. It was a comparison with the P4P which reacts right away. I tried the Cinematic mode a couple of minutes again and then it worked as it is supposed to.
Also, which device & version OS are you on? I was using a Samsung S5 on Android 4.4.2.
And I'm guessing we're all on the latest FW & GO 4 app, right?
I've got a lot of flights with this & a P4P+ and never had this happen. I hate using the flight modes because of unpredictable stuff like this! I was in Cinematic when this happened & I'm always in Normal. |
