Donnie Stugots
Flight distance : 3636782 ft
You would be on 1.3 on the RC at that point in time and you would have been on 1.4 or 1.5 on the aircraft
So you may have a damaged USB part 54 on the back of the RC ( bout 100 US dollars ) or the 1.3 may not communicate at all with the latest go app.
so here is the Plan , Take the Thmb drive that you have and format it , then I want you to load this file on tho the RC and see if you can update the RC. If it does great , then we can update via the Go app to the latest one . This should work . If the HDMI on the back the RC is bad it will not and will have to be replaced , fairly simple .
So here is the file to try , it is the 1.6 file in the link , the 1.7 wontwork , so follow my directions and then load the 1.6 file
http://forum.dji.com/thread-47572-1-1.html
If the 1.6 file does not work then try this one here , it would be the next one inorder after 1.3
The Slave RC did work before this latest update correct ? Just want to make sure it worked at one time becasue it could be on much older FW if not .
What file were you trying to use on the thumb drive on the slave RC transmitter ? only certain ones will work , you did not try one of mine already did you ? you were trying the ones on the DJI website correct ? ( these wont work , or only 1.3 would .....Maybe )
http://download.dji-innovations. ... _FW_V01.04.0030.bin
I am just trying to get you as close to 1.7 as possible , once we get one of them loaded ( either one ) then we should be able to use the go app to get to 1.7
If this does not work then I feel you may have a defective part 54 on the back of the RC as I expalined earlier , but give this a shot and we will go from there
donnie
