Sensor crop on 4K / focus handset / 12mm lens
602 0 2017-2-19
edmoore
Flight distance : 598150 ft
Hi all, in process of putting together an Inspire 2 order and figuring a few things out.
Can someone tell me if the field of view narrows when swapping to 4K from 5.2K? i.e. does the X5S use a smaller part of the sensor for 4K or does it take the whole sensor and scale the image?
I'm thinking of buying the X5S without the stock lens and instead getting the Olympus 12mm, 25mm and 45mm primes. Will I regret not having the stock 15mm? Do I really need the DJI balance rings for the other lenses or will using a normal pola or UV filter on the front have the same effect?
Do we know when batteries / second controllers are likely to be back in stock?
And finally I'm slightly unclear what benefits come from getting the DJI Focus handset (with the ABCD buttons etc) over the "focus handwheel" - it seems like both focus options have to be hardwired to the controller using the canbus cable?
Any advice greatly appreciated.
2017-2-19
