DJI GO App always Crash !
1234Next >
12246 121 2017-2-19
Cyrille1
Flight distance : 75807 ft
Hi, Since last update (iOS App Dji GO) , App always crash, very unstable and frustrating... anyone have this problem ?
Of course, i re-install app but same problem.
config : iPhone 7+ - Last iOS
Thanks for your help
2017-2-19
PhaseshiftR
It seems to be happening a lot. I have read mostly it's for people who have android but I guess it's happening to a lot of people :/ I don't have the mavic yet so I can't say man
2017-2-19
dronist
I had the MP for the past 3 month and never even had one crash. I am using IPHONE6s+ and force close all apps before connection. You are using DJI GO4 APP?  Delete the app and reinstall and see how it goes. Also try it with another phone and or cable to kind of eliminate that phone and cable. Also try it using the USB port and let us know...Good luck!
2017-2-19
Cyrille1
Thanks but already do this...
2017-2-19
theGrindLab.com
Flight distance : 1375846 ft
I've been having the same issue on my Android device with pretty much every flight. Switched to Litchi and have not had even one problem.
2017-2-19
devGOD
Flight distance : 200577 ft
i have an iPhone 7+ and an iPad Mini 4 neither DJI GO 4 app has ever crashed on me. How much available space do you have available.
2017-2-19
dronist
Cyrille1 Posted at 2017-2-19 13:25
Few people so far reported the issue with the 7+. Did you try with 6S+ or MINI 4 LIKE DEV suggested?
2017-2-19
Cyrille1
devGOD Posted at 2017-2-19 19:31
60 Go...
2017-2-19
Cyrille1
dronist Posted at 2017-2-19 19:36
No.. because i have an iPhone 7+... It does not solve my problem if App works on iPhone 6S+
2017-2-20
Angelo26
Flight distance : 799718 ft
Austria
Cyrille1 Posted at 2017-2-20 00:01
DJI GO 4 still seems to be a beta-version both for iOS and android although more androids have substantial problems than iOS-phones ..............
I tested it with 4 different androids (2 from the DJI-certified list and 2 which are not on the list) and on ALL FOUR DJI GO 4 crashes BUT NOT DJI GO 3.
DJI is strongly advised to keep DJI GO 3 "alive" until the wiped out all the innumerable bugs in DJI GO 4 !
2017-2-20
Cyrille1
in fact App works sometimes but at the end of the day (problem of memory ?) App always crash.
2017-2-20
DJI Natalia
Flight distance : 318 ft
If DJI GO 4 crashes on your android device, then please export the crash log for us, you can find it here: /sdcard/DJIdji.go.v4/LOG/CRASH
If you use an iOS device, please connect your device to a PC with iTunes installed and find the crash log.
Then upload it to dropbox and post link here, I will transfer all files to our engineers for evaluation, thank you all very much.
2017-2-20
Cyrille1
DJI Natalia Posted at 2017-2-20 00:41
Thanks but... What is the name of (dji) crash log ? i have more files...
2017-2-20
Cyrille1
Here : https://www.dropbox.com/sh/vwdde ... eBYtMVKUudDmZa?dl=0
Ok for  you ?
2017-2-20
Day In Nature
Flight distance : 69783 ft
Thailand
App constantly crashes on Nexus 5x.
But I see no LOG folder
2017-2-20
Day In Nature
Thailand
I found logs in different place.
https://www.dropbox.com/s/m8ld8mqp9eu1wvv/crash-2017-02-20-14-56-43.zip?dl=0
2017-2-20
Day In Nature
Thailand
And It looks like a simple programming mistake... Not something overcomplicated. So hoping for an app update...
2017-2-20
Cyrille1
Day In Nature Posted at 2017-2-20 01:56
yes, i hope a fix very soon
2017-2-20
MDSH
Flight distance : 334869 ft
I've said this in another thread: I'm having this crashing problem too. c app v4.0.2(172-gpPhone) running on Google Pixel XL.
I'm getting, on average, three crashes per flight.
Other issues with the DJI Go 4 app:
* if you attempt to start the app with the screen set to Landscape mode it will crash - 100% reliable
* so you've started the app in Portrait mode and you 'Go Fly' the app switches its display to landscape mode and its always upside-down, and takes a couple of seconds to appear the right way up. DJI knows where the data connector is on the Mavic controller and that all phones have the data connection at the bottom - it can't be that hard to get the orientation right.
As has been said above - its REALLY disconcerting to go blind mid flight. I wonder, would it be DJI's fault if you crashed the UAV because DJI's software crashed?
A zip of the logs from DJI/dji.go.4/LOG/CRASH are here:
https://drive.google.com/open?id=0B77EcgGiZv-lNTQ2Wkl4LXNqUVk
Please get back to me if you have more questions.
2017-2-20
b33
MDSH Posted at 2017-2-20 07:56
+1
have 100% the same issues, same phone. App keeps crashing. If i fly without fresh reboot of the phone it will go aircraft disconnected almost asap after take off. Please advice to downgrade for DJI Go 3. Very risky to fly outside any test areas.
It's not like a new problem.
2017-2-20
fans565183da
Flight distance : 109150 ft
Here's a link to my crash logs from the Android version of Go 4 - crashes quite a lot to be honest.
https://drive.google.com/drive/f ... ZjNwVTg?usp=sharing
DJI - please fix this crashing. It's 100% the application, as Litchi works perfectly with zero crashes
2017-2-20
grozmo
App crashes for me just about every flight as well (google pixel)
Where do I find the 'LOG / CRASH' there appears to be nothing on the phone?
The only thing under /dji.go.v4/ is the DJI_RECORD folder
2017-2-20
fans565183da
grozmo Posted at 2017-2-20 16:06
I'm using a Pixel as well - There should be a folder called 'LOG' located at: /internal memory/DJI/DJI.GO.V4/LOG
In there will be the crash txt files. The more crash logs that DJI get to see the better
2017-2-20
armoredsaint
i always wonder what will happen if you get a phone call when flying the mavic
2017-2-20
grozmo
fans565183da Posted at 2017-2-20 17:22
It's empty - there are no files or folders in there except the "RECORD" folder. (I've flown a number of times with this phone / app).
2017-2-20
MDSH
grozmo Posted at 2017-2-20 17:59
/storage/emulated/0/DJI/dji.go.v4/LOG/CRASH
Seen here (hopefully) using OI File Manager:
2017-2-20
crissiloop
Flight distance : 198488 ft
my crashlogs with the DJIGO4 Android App: https://drive.google.com/open?id=0BzWkwoiy1CwZYkJGaGZMWGhycGM
2017-2-21
IPA Brew
Flight distance : 538120 ft
Same Problem    DJI Go 4 app    Samsung Note 5    No problems until just recently  ..   Here are my crash logs
DJI Mavic CRASH Log
2017-2-21
Bent Kangaroo
Flight distance : 362510 ft
Same problem, forced to upgrade to this pathetic app which crashes from day effing one!
GoCrap4 needs to be recalled and we should be given option to go back to stable GoCrap3.
What good is this mavic if all it does is crashing app making it worthless.
2017-2-21
SeanFoy
im sick of this crap.  Here is my latest log.  It fails every single time on Pixel Xl.  DJI should be utterly ashamed of themselves.
java.lang.RuntimeException: Canvas: trying to draw too large(256256064bytes) bitmap.
        at android.view.DisplayListCanvas.throwIfCannotDraw(DisplayListCanvas.java:260)
        at android.graphics.Canvas.drawBitmap(Canvas.java:1415)
        at android.graphics.drawable.BitmapDrawable.draw(BitmapDrawable.java:528)
        at android.graphics.drawable.LayerDrawable.draw(LayerDrawable.java:1012)
        at android.view.View.getDrawableRenderNode(View.java:17428)
        at android.view.View.drawBackground(View.java:17364)
        at android.view.View.draw(View.java:17176)
        at com.android.internal.policy.DecorView.draw(DecorView.java:753)
        at android.view.View.updateDisplayListIfDirty(View.java:16167)
        at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:648)
        at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:654)
        at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:762)
        at android.view.ViewRootImpl.draw(ViewRootImpl.java:2800)
        at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:2608)
        at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2215)
        at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1254)
        at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:6337)
        at android.view.Choreographer$CallbackRecord.run(Choreographer.java:874)
        at android.view.Choreographer.doCallbacks(Choreographer.java:686)
        at android.view.Choreographer.doFrame(Choreographer.java:621)
        at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:860)
        at android.os.Handler.handleCallback(Handler.java:751)
        at android.os.Handler.dispatchMessage(Handler.java:95)
        at android.os.Looper.loop(Looper.java:154)
        at android.app.ActivityThread.main(ActivityThread.java:6119)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776)
2017-2-21
eyeg4et1956
Flight distance : 85272 ft
Thailand
Received my Mavic Pro on 18 Feb. Installed DJI GO 4 in the store and updated firmware.    Test flight was perfect.   Took the Mavic Pro home to charge the batteries and controller.  Studied the manual and made some changes to the default settings.  Day one, first flight on 19 Feb at a local park.  One battery flight went okay.  Changed battery and app crashed.  My Samsung S7 Edge would not restart.  Forced reboot.  Day tow, second flight on 20 Feb.  Turned off controller and phone before switching battery.  Second Battery flight okay, but videos not saved on SD card; only phone.  Day three, third flight on 21 Feb. Three batteries and just before landing phone crashed.  Mavic hovering at 30 meters over parking lot.  WOuld not return to home as programmed.  Used controller to manually land.  Phone will not restart.  Splash screen loads and repeats.  Evening 21 Feb - Wiped phone and factory reset.  Installed DJI Go 4 and it will not open; fails to respond.  Uninstalled DJI Go 4 and restarted phone.  Installed DJI Go 4 and same error.  Does not respond at all!  Two crash reports submitted.  MOrnign 22 Feb deleted DJI Go 4 and installed DJI Go.  Seems stable for now.
Android version of DJI GO 4 unstable/unusable with Samsung S7 Edge.   Makes flying the Mavic impossible!
2017-2-21
DJI-Ken
Flight distance : 1515312 ft
These are the DJI recommended devices.
Can you try one of them and see if the app crashes.
  • ios: iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPod touch 6, iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
  • Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD
2017-2-22
DJI-Ken
eyeg4et1956 Posted at 2017-2-21 17:29
These are the recommended devices, can you try one of them and see if the app crashes.
The Mavic page lists the recommended devices.
ios: iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPod touch 6, iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7 and iPhone 7 Plus.
Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD, Smartisan T1.
2017-2-22
DJI-Ken
Bent Kangaroo Posted at 2017-2-21 15:02
Are you using one of the recommended devices listed on the Mavic webpage?
2017-2-22
VAS67
Flight distance : 265984 ft
Try plugging iphone into bottom USB port instead... see if that helps?
2017-2-22
Drseussami
Flight distance : 108002 ft
My app crashes 20 times a day without me even using the app. Burning through battery and data too.
Here is my Dropbox link to crash reports
https://www.dropbox.com/sh/sbtqu ... YXfNKvNcOS_Ira?dl=0
2017-2-22
MDSH
DJI-Ken Posted at 2017-2-22 13:16
Thanks for your reply, Ken. Have you passed the crash logs onto the developers, and if so can you give me any reference number for the report?
2017-2-22
fanseb85c303
I switched to litchi.  DJI go app crashes now on every flight
2017-2-23
DJI-Ken
MDSH Posted at 2017-2-22 23:28
DJI-Natalia is handling that.
Can you try one of the DJI recommended devices to see if you still get crashes.
2017-2-23
Bent Kangaroo
DJI-Ken Posted at 2017-2-22 13:17
Are you saying the GoApp3 with absolutely ZERO crashes was replaced by an app that does nothing but crash and is now my phones fault?M ybe the app permissions could be botched but i doubt it since it crashes in flight.
No i dont believe my phone is on your list, but many phones on your list crash with GoCrap4.
If my phone works perfect on GA3 and is worthless on GA4, is not a good outcome.
2017-2-23
1234Next >
